Kappa - kody błędów EOBD
Codee
Post autor: Codee » 07 maja 2010, 19:33
BŁĘDY SILNIKA I SKRZYNI BIEGOW
P0101 Mass or Volume Air flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit low Input
P0103 Mass or Volume Air flow Circuit High Input
P0104 Mass or Volume Air flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle Pedal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0130 Ox Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 Ox Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 Ox Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 Ox Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 Ox Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 Ox Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 Ox Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 Ox Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 Ox Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 Ox Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 Ox Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 Ox Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 Ox Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 Ox Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 Ox Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 Ox Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 Ox Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 Ox Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 Ox Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 Ox Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 Ox Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 Ox Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 Ox Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 Ox Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 Ox Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 Ox Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 Ox Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 Ox Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 Ox Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 Ox Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 Ox Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 Ox Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 Ox Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 Ox Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 Ox Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 Ox Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Performance
P0182 Fuel Temperature Sensor A Circuit low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor U Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Over Speed Condition
P0220 Throttle/Pedal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Turbocharger Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Circuit Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection lump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Balance Fault
P0298 Engine Oil Over Temperature
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire Detected with Low Fuel
P0314 Single Cylinder Misfire (Cylinder not Specified)
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" circuit Malfunction
P0419 Secondary Air Injection System Relay "B? Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank l)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge flow
P0442 Evaporative Emission Control System leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Tank Detected (gross leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0486 Exhaust Gas Recirculation Sensor "B" Circuit
P0487 Exhaust Gas Recirculation Throttle Position Control Circuit
P0488 Exhaust Gas Recirculation Throttle Position Control Range/Performance
P0491 Secondary Air Injection System (Bank 1)
P0492 Secondary Air Injection System (Bank 2)
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Circuit Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM lower Than Expected
P0507 Idle Control System RPM higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Low Voltage
P0523 Engine Oil Pressure Sensor/Switch High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control System - Vehicle Speed Too High
P0575 Cruise Control Input Circuit
P0576 Cruise Control Input Circuit Low
P0577 Cruise Control Input Circuit High
P0578 through P0580 Reserved for Cruise Control Codes
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
(Module Identification Defined by SAE J1979)
P0606 ECM/PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0610 Control Module VSS Output "B" Malfunction
P0615 Starter Relay Circuit
P0616 Starter Relay Circuit Low
P0617 Starter Relay Circuit High
P0618 Alternative Fuel Control Module KAM Error
P0619 Alternative Fuel Control Module RAM/ROM Error
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0623 Generator Lamp Control Circuit
P0624 Fuel Cap Lamp Control Circuit
P0630 VIN Not Programmed or Mismatch - ECM/PCM
P0631 VIN Not Programmed or Mismatch - TCM
P0635 Power Steering Control Circuit
P0636 Power Steering Control Circuit Low
P0637 Power Steering Control Circuit High
P0638 Throttle Actuator Control Range/Performance (Bank 1)
P0639 Throttle Actuator Control Range/Performance (Bank 2)
P0640 Intake Air Heater Control Circuit
P0645 A/C Clutch Relay Control Circuit
P0646 A/C Clutch Relay Control Circuit Low
P0647 A/C Clutch Relay Control Circuit High
P0648 Immobilizer Lamp Control Circuit
P0649 Speed Control Lamp Control Circuit
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfunction
P0656 Fuel Level Output Circuit Malfunction
P0660 Intake Manifold Tuning Valve Control Circuit (Bank 1)
P0661 Intake Manifold Tuning Valve Control Circuit Low (Bank 1)
P0662 Intake Manifold Tuning Valve Control Circuit High (Bank 1)
P0663 Intake Manifold Tuning Valve Control Circuit (Bank 2)
P0664 Intake Manifold Tuning Valve Control Circuit Low (Bank 2)
P0665 Intake Manifold Tuning Valve Control Circuit High (Bank 2)
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Circuit Range/Performance
P0722 Output Speed Sensor Circuit No Signal
P0723 Output Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed Input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0775 Pressure Control Solenoid "B"
P0776 Pressure Control Solenoid "B" Performance or Stuck off
P0777 Pressure Control Solenoid "B" Stuck On
P0778 Pressure Control Solenoid "B" Electrical
P0779 Pressure Control Solenoid "B" Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0791 Intermediate Shaft Speed Sensor Circuit
P0792 Intermediate Shaft Speed Sensor Circuit Range/Performance
P0793 Intermediate Shaft Speed Sensor Circuit No signal
P0794 Intermediate Shaft Speed Sensor Circuit Intermittent
P0795 Pressure Control Solenoid "C"
P0796 Pressure Control Solenoid "C" Performance or Stuck off
P0797 Pressure Control Solenoid "C" Stuck On
P0798 Pressure Control Solenoid "C" Electrical
P0799 Pressure Control Solenoid "C" Intermittent
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P0805 Clutch Position Sensor Circuit Malfunction
P0806 Clutch Position Sensor Circuit Range/Performance Malfunction
P0807 Clutch Position Sensor Circuit Low Malfunction
P0808 Clutch Position Sensor Circuit High Malfunction
P0809 Clutch Position Sensor Circuit Intermittent Malfunction
P0810 Clutch Position Control Error
P0811 Excessive Clutch Slippage
P0812 Reverse Input Circuit
P0813 Reverse Output Circuit
P0814 Transmission Range Display Circuit
P0815 Upshift Switch Circuit
P0816 Downshift Switch Circuit
P0817 Starter Disable Circuit
P0818 Driveline Disconnect Switch Input Circuit
P0820 Gear Lever X - Y Position Sensor Circuit
P0821 Gear Lever X Position Circuit
P0822 Gear Lever Y Position Circuit
P0823 Gear Lever X Position Circuit Intermittent
P0824 Gear Lever Y Position Circuit Intermittent
P0825 Gear Lever Push - Pull Switch (Shift Anticipate)
P0830 Clutch Pedal Switch "A" Circuit
P0831 Clutch Pedal Switch "A" Circuit Low
P0832 Clutch Pedal Switch "A" Circuit High
P0833 Clutch Pedal Switch "B" Circuit
P0834 Clutch Pedal Switch "B" Circuit Low
P0835 Clutch Pedal Switch "B" Circuit High
P0836 Four Wheel Drive (4WD) Switch Circuit
P0837 Four Wheel Drive (4WD) Switch Circuit Range/Performance
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P0840 Transmission Fluid Pressure Sensor/Switch "A" Circuit
P0841 Transmission Fluid Pressure Sensor/Switch "A" Circuit Range/Performance
P0842 Transmission Fluid Pressure Sensor/Switch "A" Circuit Low
P0843 Transmission Fluid Pressure Sensor/Switch "A" Circuit High
P0844 Transmission Fluid Pressure Sensor/Switch "A" Circuit Intermittent
P0845 Transmission Fluid Pressure Sensor/Switch "B" Circuit
P0846 Transmission Fluid Pressure Sensor/Switch "B" Circuit Range/Performance
P0847 Transmission Fluid Pressure Sensor/Switch "B" Circuit Low
P0848 Transmission Fluid Pressure Sensor/Switch "B" Circuit High
P0849 Transmission Fluid Pressure Sensor/Switch "B" Circuit Intermittent
Codee
Re: KODY BŁĘDÓW EOBD
Post autor: Codee » 07 maja 2010, 19:34
P1000 OBD II Test Incomplete (Mazda)
P1000 Monitor Testing Not Complete (Ford)
P1001 KOER Not Able To Complete, KOER Aborted (Ford)
P1100 MAF Intermittant (Mazda)
P1101 MAF Out Of Range (Mazda)
P1106 Manifold Absolute Pressure (MAP) sensor circuit intermittent high voltage
P1107 Manifold Absolute Pressure (MAP) sensor circuit intermittent low voltage
P1108 BARO to MAP signal circuit comparison too high
P1111 Intake Air Temperature (IAT) sensor intermittent high voltage
P1112 Intake Air Temperature (IAT) sensor intermittent low voltage
P1114 Engine Coolant Temperature (ECT) sensor circuit intermittent low voltage
P1115 Engine Coolant Temperature (ECT) sensor circuit intermittent high voltage
P1115 Intake Air Temperature 2 Circuit High Input (Ford)
P1116 ECT Sensor Out Of Range (Mazda)
P1116 ECT Sensor Out Of Range (Ford)
P1117 ECT Intermittent (Mazda)
P1117 ECT Intermittent (Ford)
P1120 TPS Out Of Range Low (Mazda)
P1120 TPS Out Of Range Low (Ford)
P1121 Throttle Position (TP) Sensor Inconsistent With MAF Sensor High Voltage
P1122 Throttle Position (TP) Sensor Inconsistent With MAF Sensor Low Voltage
P1124 TPS Out Of Self Teat Range (Mazda)
P1124 TPS Out Of Self Teat Range (Ford)
P1125 TPS Intermittant (Mazda)
P1125 TPS Intermittant (Ford)
P1127 Exhaust Not Warm Enough, Downstream Sensor Not Tested (Ford)
P1128 MAP Lower Than Expected (Acura)
P1129 Upstream O2 Sensors Swapped Bank To Bank (HO2S-11-21) (Ford)
P1129 MAP Higher Than Expected (Acura)
P1129 Downstream O2 Sensors Swapped Bank To Bank (HO2S-12-22) (Ford)
P1130 Heated O2 Sensor (HO2S) 11 At Adaptive Limit (Mazda)
P1130 Lack Of HO2S-11, Fuel Trim At Limit (Ford)
P1131 HO2S 11 Indicates Lean (Mazda)
P1131 HO2S 11 Indicates Lean (Ford)
P1132 HO2S 11 Indicates Rich (Mazda)
P1132 HO2S 11 Indicates Rich (Ford)
P1133 Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1 (Rear Bank)
P1134 Heated Oxygen Sensor (HO2S) transition time ratio bank 1 sensor 1 (Rear Bank)
P1137 Lack Of HO2S-12 Switch Indicates Lean (Ford)
P1138 Lack Of HO2S-12 Switch Indicates Rich (Ford)
P1150 Lack Of HO2S-21 Switch Fuel Trim At Limit (Ford)
P1151 Lack Of HO2S-21 Switch Indicates Lean (Ford)
P1152 Lack Of HO2S-21 Switch Indicates Rich (Ford)
P1153 Heated Oxygen Sensor (HO2S) insufficient switching bank 2 sensor 1 (Front Bank)
P1154 Heated Oxygen Sensor (HO2S) transition time ratio bank 2 sensor 1 (Front Bank)
P1157 Lack Of HO2S-22 Switch Indicates Lean (Ford)
P1158 Lack Of HO2S-22 Switch Indicates Rich (Ford)
P1168 FRP Sensor In Range But Low (Ford)
P1169 FRP Sensor In Range But High (Ford)
P1180 Fuel Delivery System Low (Ford)
P1181 Fuel Delivery System High (Ford)
P1183 EOT Sensor Circuit Malfunction (Ford)
P1184 EOT Sensor Out Of Range (Ford)
P1189 Engine Oil Pressure Switch Circuit
P1192 Inlet Air Temp. Circuit Low (Chrysler)
P1193 Inlet Air Temp. Circuit High (Chrysler)
P1195 1/1 O2 Sensor Slow During Catalyst Monitor (Chrysler)
P1196 2/1 O2 Sensor Slow During Catalyst Monitor (Chrysler)
P1197 1/2 O2 Sensor Slow During Catalyst Monitor (Chrysler)
P1198 Radiator Temperature Sensor Volts Too High (Chrysler)
P1199 Radiator Temperature Sensor Volts Too Low (Chrysler)
P1229 Super charger Intercooler Pump Not Working (Ford)
P1232 Low Speed Fuel Pump Primary Circuit Malfunction (Ford)
P1233 Fuel System Disabled Or Offline (Ford)
P1234 Fuel System Disabled Or Offline (Ford)
P1235 Fuel Pump Control Out Of Range (Ford)
P1236 Fuel Pump Control Out Of Range (Ford)
P1237 Fuel Pump Secondary Circuit Malfunction (Ford)
P1238 Fuel Pump Secondary Circuit Malfunction (Ford)
P1244 Generator Load Low (Ford)
P1245 Generator Load Input High (Ford)
P1246 Generator Load Input Failed (Ford)
P1258 Engine Metal Over Temperature Protection
P1259 VTEC System Malfunction (Acura)
P1260 Fuel Pump Speed Relay Control Circuit (GM)
P1260 Theft Detected - Engine Disabled (Mazda)
P1260 Theft Detected - Engine Disabled (Ford)
P1270 Vehicle Speed Limiter Reached (Mazda)
P1270 Vehicle Speed Limiter Reached (Ford)
P1281 Engine Is Cold Too Long (Chrysler)
P1282 Fuel Pump Relay Control Circuit(Chrysler)
P1285 Cylinder Head Over Temperature Sensed (Ford)
P1288 Intake Manifold Short Runner Solenoid Circuit (Chrysler)
P1290 CHT Sensor Out Of Range (Ford)
P1289 Manifold Tune Valve Solenoid Circuit (Chrysler)
P1289 CHT Sensor High Input (Ford)
P1290 CNG Fuel Pressure Too High (Chrysler)
P1290 CHT Sensor Low Input (Ford)
P1291 No Temp Rise Seen From Fuel Heaters (Chrysler)
P1292 CNG Pressure Sensor Voltage Too High (Chrysler)
P1293 CNG Pressure Sensor Voltage Too Low (Chrysler)
P1294 Target Idle Not Reached (Chrysler)
P1295 No 5 Volts To TP Sensor (Chrysler)
P1296 No 5 Volts To MAP Sensor (Chrysler)
P1297 No Change in MAB From Start To Run (Chrysler)
P1297 Low Voltage ELD Circuit (Acura)
P1298 High Voltage In ELD Circuit (Acura)
P1298 Lean Operation At wide Open Throttle (Chrysler)
P1299 Vacuum Leak Found (IAC Fully Seated)(Chrysler)
P1299 Cylinder Head Over Temperature Protection Active (Ford)
P1300 Random Misfire (Acura)
P1309 Misfire Monitor Disabled (Ford)
P1320 Ignition Control (IC) Module 4x Reference Circuit Intermittent No Pulses
P1323 Ignition Control (IC) Module 24x Reference Circuit low frequency
P1336 Crankshaft Position System Variation Not Learned (GM)
P1336 Crankshaft Speed Fluctuation Sensor Intermittant Interruption (Acura)
P1337 Crankshaft Speed Fluctuation Sensor No Signal (Acura)
P1350 Ignition Control System
P1351 Ignition Coil Control Circuit High Voltage (GM)
P1352 Ignition Bypass Circuit High Voltage (GM)
P1359 Crankshaft Position/TDC/Cylinder Position Sensor Connector Disconnection (Acura)
P1361 Intermittent Interruption In TDC1 Sensor Circuit (Acura)
P1361 Ignition Control (IC) Circuit Low Voltage (GM)
P1362 No Signal In TDC1 Sensor Circuit (Acura)
P1362 Ignition Bypass Circuit Low Voltage (GM)
P1366 Intermittent Interruption In TDC2 Sensor Circuit (Acura)
P1367 No Signal In TDC2 Sensor Circuit (Acura)
P1370 Ignition Control (IC) Module 4x Reference too many pulses
P1371 Ignition Control (IC) Module 4x Reference too few pulses
P1374 CKP High to Low Resolution Frequency Correlation (GM)
P1375 Ignition Control (IC) Module 24x Reference High Voltage
P1376 Ignition Ground Circuit
P1377 Ignition Control (IC) Module Cam Pulse to 4x Reference Pulse Comparison
P1380 EBTCM DTC Detected-Rough Data Unusable
P1380 Variable Cam Timing Solenoid A Circuit Malfunction (Ford)
P1381 Misfire Detected-No EBTCM/PCM Serial Data
P1381 Cylinder Position Sensor Intermittant Inturruption (Acura)
P1381 Variable Cam Timing Over-advanced (Bank 1) (Ford)
P1382 Cylinder Position Sensor No Signal (Acura)
P1383 Variable Cam Timing Over-retarded (Bank 1) (Ford)
P1388 Auto Shutdown Relay Circuit (Chrysler)
P1389 No ASD Relay Output Voltage At PCM (Chrysler)
P1390 Timing Belt Skipped One Tooth or More (Chrysler)
P1390 Octane Adjust Out Of Range (Mazda)
P1391 Intermittent Loss of CMP or CKP (Chrysler)
P1398 Mis-Fire Adapter Numerator at Limit (Chrysler)
P1399 Wait To Start Lamp Circuit (Chrysler)
P1400 DPFE Sensor Low Voltage (Mazda)
P1400 DPFE Sensor Low Voltage (Ford)
P1401 DPFE Sensor High Voltage (Mazda)
P1401 DPFE Sensor High Voltage (Ford)
P1403 DPFE Hoses Reversed (Mazda)
P1403 No 5 Volts To EGR Sensor (Chrysler)
P1404 Exhaust Gas Recirculation (EGR) Valve Pintle Stuck Open
P1405 DPFE Upstream Hose Off Or Plugged (Mazda)
P1405 DPFE Upstream Hose Off Or Plugged (Ford)
P1406 DPFE Downstream Hose Off Or Plugged (Mazda)
P1406 DPFE Downstream Hose Off Or Plugged (Ford)
P1407 EGR No Flow Detected (Mazda)
P1408 EGR Out Of Self Test Range (Mazda)
P1408 EGR Out Of Self Test Range (Ford)
P1409 Electronic Vacuum Regulator Control Circuit Malfunction (Mazda)
P1409 EGR Vacuum Regulator Solenoid Circuit Malfunction (Ford)
P1411 Secondary Air Injection System Downstream Flow (Ford)
P1413 Secondary Air Injection System Monitor Circuit Low (Ford)
P1414 Secondary Air Injection System Monitor Circuit High (Ford)
P1432 THTRC Circuit Failure (Ford)
P1441 Evaporative System Flow During Non-Purge
P1443 Evapor ative Emission Control System (Mazda)
P1443 Small Or No Purge Flow Condition (Ford)
P1444 Purge Flow Sensor Low Input (Mazda)
P1445 Purge Flow Sensor High Input (Mazda)
P1450 Unable To Bleed Up Fuel Tank Vacuum (Ford)
P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction (Ford)
P1457 Leak Detected In EVAP Control Sys.(EVAP Canister Sys.) (Acura)
P1460 WOT A/C Cutoff Circuit Malfunction (Mazda)
P1460 WOT A/C Cutoff Circuit Malfunction (Ford)
P1461 ACP Sensor High Voltage (Ford)
P1462 ACP Sensor Low Voltage (Ford)
P1463 ACP Sensor Insufficent Pressure Change (Ford)
P1464 A/C Demand Out Of Range (Ford)
P1469 Low A/C Cycling Period (Ford)
P1474 HCF Primary Circuit Failure (Ford)
P1474 LFC Primary Circuit Failure (Ford)
P1476 Too Little Secondary Air (Chrysler)
P1477 Too Much Secondary Air (Chrysler)
P1477 MFC Primary Circuit Failure (Ford)
P1478 Battery Temp Sensor Volts Out of Limit (Chrysler)
P1479 HFC Primary Circuit Failure (Ford)
P1479 Transmission Fan Relay Circuit (Chrysler)
P1480 PCV Solenoid Valve (Chrysler)
P1482 Catalyst Temperature Sensor Circuit Shorted Low (Chrysler)
P1483 Engine Cooling System Performance
P1483 Catalyst Temperature Sensor Circuit Shorted High (Chrysler)
P1484 Catalytic Converter overheat Detected (Chrysler)
P1485 Air Injection Solenoid Circuit (Chrysler)
P1486 Evap Leak Monitor Pinched Hose (Chrysler)
P1487 Hi Speed Rad Fan CTRL Relay Circuit (Chrysler)
P1488 Auxiliary 5 Volt Supply Output Too Low (Chrysler)
P1489 High Speed Fan CTRL Relay Circuit (Chrysler)
P1490 Low Speed Fan CTRL Relay Circuit (Chrysler)
P1491 Rad Fan Control Relay Circuit (Chrysler)
P1491 Malfunction In EGR System (Acura)
P1492 Ambient/Batt Temp Sen Volts Too High (Chrysler)
P1493 Ambient/Batt Temp Sen Volts Too Low (Chrysler)
P1494 Leak Detection Pump Switch or Mechanical Fault (Chrysler)
P1495 Leak Detection Pump Solenoid Circuit (Chrysler)
P1496 5 Volt Supply Output Too Low (Chrysler)
P1498 High speed Rad Fan Ground CTRL Rly Circuit (Chrysler)
P1498 Voltage Problem In EGR Valve Position Sensor Circuit (Acura)
P1500 Vehicle Speed Sensor (VSS) (Mazda)
P1500 Vehicle Speed Sensor (VSS) Intermittant (Ford)
P1501 Vehicle Speed Sensor (VSS) Out Of Range (Ford)
P1502 Vehicle Speed Sensor (VSS) Intermittant (Ford)
P1505 Idle Air Control At Adaptive Clip (Mazda)
P1506 Idle Air Control System Overspeed Error (Mazda)
P1506 Idle Air Control System Overspeed Error (Ford)
P1507 Idle Air Control System Underspeed Error (Mazda)
P1507 Idle Air Control System Underspeed Error (Ford)
P1508 Idle Air Control (IAC) System - Low RPM
P1508 Idle Air Control Valve Circuit Failure (Acura)
P1516 Inlet Manifold Runner Control Input Error (Bank 1) (Ford)
P1517 Inlet Manifold Runner Control Input Error (Bank 2) (Ford)
P1518 Inlet Manifold Runner Control Stuck Open (Ford)
P1519 Malfunction In IAC Valve Circuit (Acura)
P1519 Inlet Manifold Runner Control Stuck Closed (Ford)
P1520 Intake Manifold Runner Control (IMRC) circuit malfunction
P1524 Throttle Position (TP) Sensor Learned Closed Throttle Angle Degrees Out-Of-Range
P1527 Trans Range / Pressure Switch Comparison
P1546 Air Conditioning (A/C) Clutch Relay Control Circuit (GM)
P1549 Intake Manifold Control Circuit Malfunction (Ford)
P1550 PSP Sensor Malfunction (Ford)
P1554 Cruise Engaged Circuit High Voltage
P1560 Cruise Control System-Transaxle Not in Drive
P1564 Cruise Control System-Vehicle Acceleration too high
P1566 Cruise Control System-Engine RPM Too High
P1567 Cruise Control- ABCS Active
P1570 Cruise Control System - Traction Control Active
P1571 Traction Control System PWM Circuit No Frequency
P1572 Brake Pedal Switch Circuit (Ford)
P1574 EBTCM System- Stop Lamp Switch Circuit High Voltage
P1575 Extended Travel Brake Switch Circuit High Voltage
P1579 Park/Neutral to Drive/Reverse At high Throttle Angle
P1585 Cruise Control Inhibit Output Circuit (GM)
P1594 Charging System Voltage Too High (Chrysler)
P1595 Speed Control Solenoid Circuits (Chrysler)
P1596 Speed Control Switch always High (Chrysler)
P1597 Speed Control Switch always Low (Chrysler)
P1598 A/C Pressure Sensor Volts Too High (Chrysler)
P1599 A/C Pressure Sensor Volts Too Low (Chrysler)
P1599 Engine Stall or Near Stall Detected
P1602 Loss of EBTCM Serial Data
P1603 Loss of SDM Serial Data
P1604 Loss of IPC Serial Data
P1605 Loss of HVACC Serial Data
P1605 Keep Alive Memory Failure (Ford)
P1605 Powertrain Control Module (Mazda)
P1607 Malfunction In PCM Internal Circuit (Acura)
P1610 Loss of PZM Serial Data
P1611 Loss of CVRTD Serial Data
P1617 Engine Oil Level Switch Circuit
P1621 PCM Memory Performance
P1626 Theft Deterrent System - Fuel Enable Circuit
P1630 Theft Deterrent - PCM in Learn Mode
P1631 Theft Deterrent - Password Incorrect
P1632 Theft Deterrent - Fuel Disabled
P1633 Ignition Supplement Power Circuit Low Voltage
P1633 Keep Alive Power Voltage Too Low (Ford)
P1634 Ignition 1 Power Circuit Low Voltage
P1635 5 Volt Reference Circuit (GM)
P1635 Tire/Axle Out Of Acceptable Range (Ford)
P1639 5 Volt Reference 2 Circuit (GM)
P1639 Vehicle ID Block Not Programmed Or Corrupt (Ford)
P1640 DTC's Available In Another Module (Ford)
P1640 Driver 1 - Input High Voltage
P1641 Malfunction Indicator Lamp (MIL) Control Circuit
P1642 Vehicle Speed Output Circuit
P1644 Delivered Torque Output Circuit
P1645 EVAP Solenoid Output Circuit
P1646 EVAP Vent Valve Output Circuit
P1650 Driver 2 - Input High Voltage
P1650 Power Steering Pressure Switch Malfunction (Ford)
P1650 Power Steering Pressure Switch Out Of Range (Mazda)
P1651 Power Steering Pressure Switch Input Malfunction (Mazda)
P1651 Power Steering Pressure Switch Signal Malfunction (Ford)
P1652 Lift/Dive Circuit
P1654 Cruise Disable Output Circuit
P1656 Automatic Transaxle (Acura)
P1660 Cooling Fan Control Circuits
P1660 A/T FI Data Line Failure (Acura)
P1676 FPTDR Signal Failure (Acura)
P1678 FPTDR Signal Line Failure (Acura)
P1680 Clutch Released Switch Circuit (CHRYSLER)
P1681 No I/P Cluster CCD/J1850 Messages Received (CHRYSLER)
P1681 A/T FI Signal A Low Input (Acura)
P1682 A/T FI Signal A High Input (Acura)
P1682 Charging System Voltage Too Low (CHRYSLER)
P1683 Speed Control Power Relay or S/C 12V Driver Circuit (CHRYSLER)
P1685 Skim Invalid Key(CHRYSLER)
P1686 No SKIM Bus Message Received (CHRYSLER)
P1686 A/T FI Signal B Low Input (Acura)
P1687 A/T FI Signal B High Input (Acura)
P1687 No Cluster Bus Message (CHRYSLER)
P1689 Traction Control Delivered Torque Output Circuit (GM)
P1693 DTC Detected In Companion Mode (CHRYSLER)
P1694 Fault In Companion Mode (CHRYSLER)
P1695 No CCD/J185O Message From BCM (CHRYSLER)
P1696 PCM Failure EEPROM Write Denied (CHRYSLER)
P1697 PCM Failure SRI Mile Not Stored (CHRYSLER)
P1698 No Bus Message From TCM (CHRYSLER)
P1701 Transmission Solenoid Malfunction (Mazda)
P1703 Brake On/Off Switch (Mazda)
P1703 Brake On/Off Switch Out Of Range (Ford)
P1705 Automatic Transaxle (Acura)
P1705 Transmisson Range Sensor Out Of Range (Ford)
P1705 Transmisson Range Sensor (Mazda)
P1706 Automatic Transaxle (Acura)
P1709 Automatic Transaxle (Acura)
P1709 Park/Neutral Position Switch (Mazda)
P1709 Park/Neutral Position Switch Out Of Range (Ford)
P1710 Automatic Transaxle (Acura)
P1711 Transmission Fluid Temperature Sensor (Mazda)
P1713 Automatic Transaxle (Acura)
P1719 Skip Shift Solenoid Circuit (Chrysler)
P1729 4x4 Low Switch (Mazda)
P1729 4x4 Low Switch Malfunction (Ford)
P1738 Automatic Transaxle (Acura)
P1739 Automatic Transaxle (Acura)
P1740 Automatic Transaxle (Acura)
P1746 EPC Solenoid Failed Low (Mazda)
P1747 EPC Solenoid Short Circuit (Mazda)
P1749 EPC Solenoid Open Circuit (Mazda)
P1751 Shift Solenoid #1 (SS1) (Mazda)
P1753 Automatic Transaxle (Acura)
P1754 Coast Clutch Solenoid (Mazda)
P1756 GOV Press Not Equal To Target @ 15-20 PSI (Chrysler)
P1756 Shift Solenoid #2 (SS2) (Mazda)
P1757 GOV Press Not Equal To Target @ 15-20 PSI (Chrysler)
P1758 Automatic Transaxle (Acura)
P1761 Shift Solenoid #3 (SS3) (Mazda)
P1762 Gov Press Sen Offset Volts Too Low or high(Chrysler)
P1763 Governor Pressure Sensor Volts Too High (Chrysler)
P1764 Governor Pressure Sensor Volts Too Low (Chrysler)
P1765 Trans 12 Volt Supply Relay CTRL Circuit (Chrysler)
P1768 Automatic Transaxle (Acura)
P1773 Automatic Transaxle (Acura)
P1778 Automatic Transaxle (Acura)
P1780 Transmission Control Switch (Mazda)
P1780 Transmission Control Switch Out Of Range(Ford)
P1781 4x4 Switch Out Of Range (Ford)
P1781 4x4 Low Switch (Mazda)
P1783 Transmission Over Temperature Condition (Mazda)
P1786 Automatic Transaxle (Acura)
P1790 Automatic Transaxle (Acura)
P1791 Automatic Transaxle (Acura)
P1792 Automatic Transaxle (Acura)
P1794 Automatic Transaxle (Acura)
P1810 TFP Valve Position Switch Circuit (GM)
P1811 Maximum Adapt and Long Shift (GM)
P1819 Internal Mode Switch - No Start/Wrong Range (GM)
P1820 Internal Mode Switch Circuit A Low (GM)
P1822 Internal Mode Switch Circuit B High (GM)
P1823 Internal Mode Switch Circuit P Low (GM)
P1825 Internal Mode Switch - Invalid Range (GM)
P1826 Internal Mode Switch Circuit C High (GM)
P1860 TCC PWM Solenoid Circuit Electrical (GM)
P1887 TCC Release Switch Circuit (GM)
P1899 Park/Neutral Position Switch Stuck In Park or In Gear (CHRYSLER)
Codee
Post autor: Codee » 07 maja 2010, 19:36
ABS & TCS Systems
C0000 - Vehicle Speed Information Circuit Malfunction
C0035 - Left Front Wheel Speed Circuit Malfunction
C0040 - Right Front Wheel Speed Circuit Malfunction
C0041 - Right Front Wheel Circuit Range/Performance (EBCM)
C0045 - Left Rear Wheel Speed Circuit Malfunction
C0046 - Left Rear Wheel Speed Sensor Circuit Range/Performance (EBCM)
C0050 - Right Rear Wheel Speed Circuit Malfunction
C0051 - LF Wheel Speed Sensor Circuit Range/Performance (EBCM)
C0060 - Left Front ABS Solenoid #1 Circuit Malfunction
C0065 - Left Front ABS Solenoid #2 Circuit Malfunction
C0070 - Right Front ABS Solenoid #1 Circuit Malfunction
C0075 - Right Front ABS Solenoid #2 Circuit Malfunction
C0080 - Left Rear ABS Solenoid #1 Circuit Malfunction
C0085 - Left Rear ABS Solenoid #2 Circuit Malfunction
C0090 - Right Rear ABS Solenoid #1 Circuit Malfunction
C0095 - Right Rear ABS Solenoid #2 Circuit Malfunction
C0110 - Pump Motor Circuit Malfunction
C0121 - Valve Relay Circuit Malfunction
C0128 - Low Brake Fluid Circuit Low
C0141 - Left TCS Solenoid #1 Circuit Malfunction
C0146 - Left TCS Solenoid #2 Circuit Malfunction
C0151 - Right TCS Solenoid #1 Circuit Malfunction
C0156 - Right TCS Solenoid #2 Circuit Malfunction
C0161 - ABS/TCS Brake Switch Circuit Malfunction
C0221 - Right Front Wheel Speed Sensor Circuit Open
C0222 - Right Front Wheel Speed Signal Missing
C0223 - Right Front Wheel Speed Signal Erratic
C0225 - Left Front Wheel Speed Sensor Circuit Open
C0226 - Left Front Wheel Speed Signal Missing
C0227 - Left Front Wheel Speed Signal Erratic
C0229 - Drop Out of Front Wheel Speed Signals
C0235 - Rear Wheel Speed Signal Circuit Open
C0236 - Rear Wheel Speed Signal Circuit Missing
C0237 - Rear Wheel Speed Signal Erratic
C0238 - Wheel Speed Mismatch
C0241 - EBCM Control Valve Circuit
C0245 - Wheel Speed Sensor Frequency Error
C0254 - EBCM Control Valve Circuit
C0265 - EBCM Relay Circuit
C0266 - EBCM Relay Circuit
C0267 - Pump Motor Circuit Open/Shorted
C0268 - Pump Motor Circuit Open/Shorted
C0269 - Excessive Dump/Isolation Time
C0271 - EBCM Malfunction
C0272 - EBCM Malfunction
C0273 - EBCM Malfunction
C0274 - Excessive Dump/Isolation Time
C0279 - Powertrain Configuration Not Valid
C0281 - Brake Switch Circuit
C0283 - Traction Switch Shorted to Ground
C0284 - EBCM Malfunction
C0286 - ABS Indicator Lamp Circuit Shorted to B+
C0287 - Delivered Torque Circuit
C0288 - Brake Warning Lamp Circuit Shorted to B+
C0290 - Lost Communications With PCM
C0292 - Lost Communications With PCM
C0291 - Lost Communications With BCM
C0297 - Powertrain Configuration Data Not Received
C0298 - Powertrain Indicated Traction Control Malfunction
C0300 - Rear Speed Sensor Malfunction
C0305 - Front Speed Sensor Malfunction
C0306 - Motor A or B Circuit
C0308 - Motor A/B Circuit Low
C0309 - Motor A/B Circuit High
C0310 - Motor A/B Circuit Open
C0315 - Motor Ground Circuit Open
C0321 - Transfer Case Lock Circuit
C0323 - T-Case Lock Circuit Low
C0324 - T-Case Lock Circuit High
C0327 - Encoder Circuit Malfunction
C0357 - Park Switch Circuit High
C0359 - Four Wheel Drive Low Range (4LO) Discrete Output Circuit
C0362 - 4LO Discrete Output Circuit High
C0367 - Front Axle Control Circuit High
C0374 - General System Malfunction
C0376 - Front/Rear Shaft Speed Mismatch
C0379 - Front Axle System
C0387 - Unable to Perform Shift
C0472 - Steering Handwheel Speed Sensor Signal V Low
C0473 - Steering Handwheel Speed Sensor Signal V High
C0495 - EVO Tracking Error
C0498 - Steering Assist Control Actuator Feed Circuit Low
C0499 - Steering Assist Control Solenoid Feed Circuit High
C0503 - Steering Assist Control Solenoid Return Circuit Low
C0504 - Steering Assist Control Solenoid Return Circuit High
C0550 - ECU Malfunction - internal write / checksum malfunction
C0559 - EEPROM Checksum Error
C0563 - Calibration ROM Checksum Error
C0577 - Left Front Solenoid Circuit Low
C0578 - Left Front Solenoid Circuit High
C0579 - Left Front Solenoid Circuit Open
C0582 - Right Front Solenoid Circuit Low
C0583 - Right Front Solenoid Circuit High
C0584 - Right Front Solenoid Circuit Open
C0587 - Left Rear Solenoid Circuit Low
C0588 - Left Rear Solenoid Circuit High
C0589 - Left Rear Solenoid Circuit Open
C0592 - Right Rear Solenoid Circuit Low
C0593 - Right Rear Solenoid Circuit High
C0594 - Right Rear Solenoid Circuit Open
C0611 - VIN Information Error
C0615 - Left Front Position Sensor Malfunction
C0620 - Right Front Position Sensor Malfunction
C0625 - Left Rear Position Sensor Malfunction
C0628 - Level Control Position Sensor Circuit High
C0630 - Right Rear Position Sensor Malfunction
C0635 - Left Front Normal Force Circuit Malfunction
C0638 - Left Front Normal Force Circuit High
C0640 - Right Front Normal Force Circuit Malfunction
C0643 - Right Front Normal Force Circuit High
C0655 - Level Control Compressor Relay Malfunction
C0657 - Level Control Compressor Circuit Low
C0658 - Level Control Compressor Circuit High
C0660 - Level Control Exhaust Valve Circuit Malfunction
C0662 - Level Control Exhaust Valve Circuit Low
C0663 - Level Control Exhaust Valve Circuit High
C0665 - Chassis Pitch Signal Circuit
C0690 - Damper Control Relay Circuit Malfunction
C0691 - Damper Control Relay Circuit Range
C0693 - Damper Control Relay Circuit High
C0695 - Position Sensor Overcurrent (8 volt supply)
C0696 - Position Sensor Overcurrent (5 volt supply)
C0710 - Steering Position Signal Malfunction
C0750 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0755 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0760 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0765 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0800 - Device Power #1 Circuit Malfunction
C0896 - Electronic Suspension Control (ESC) voltage is outside the normal range of 9 to 15.5 volts
C1211 - ABS Indicator Lamp Circuit Malfunction
C1214 - System Relay Contact or Coil Circuit Open
C1217 - Pump Motor Shorted to Ground
C1218 - Pump Motor Circuit Shorted to Voltage or Motor Ground Open
C1221 - Left Front Wheel Speed Sensor Input Signal is 0
C1222 - Right Front Wheel Speed Sensor Input Signal is 0
C1223 - Left Rear Wheel Speed Sensor Input Signal is 0
C1224 - Right Rear Wheel Speed Sensor Input Signal is 0
C1225 - Left Front Excessive Wheel Speed Variation
C1226 - Right Front Excessive Wheel Speed Variation
C1227 - Left Rear Excessive Wheel Speed Variation
C1228 - Right Rear Excessive Wheel Speed Variation
C1232 - Left Front Wheel Speed Circuit Open or Shorted
C1233 - Right Front Wheel Speed Circuit Open or Shorted
C1234 - Left Rear Wheel Speed Circuit Open or Shorted
C1235 - Right Rear Wheel Speed Circuit Open or Shorted
C1236 - Low System Supply Voltage
C1237 - High System Supply Voltage
C1238 - Brake Thermal Model Exceeded
C1241 - Variable Effort Steering Circuit Malfunction
C1242 - Pump Motor Circuit Open
C1243 - BPMV Pump Motor Stalled
C1244 - Powertrain Indicated Engine Drag Control Malfunction
C1246 - Brake Lining Wear Circuit Open
C1248 - EBCM Turned the Red Brake Warning Indicator On
C1251 - RSS Indicated Malfunction
C1252 - Left Front Normal Force Malfunction
C1253 - Right Front Normal Force Malfunction
C1254 - Abnormal Shutdown Detected
C1255 - EBCM Internal Malfunction
C1256 - EBCM Internal Malfunction
C1261 - Left Front Inlet Valve Solenoid Malfunction
C1262 - Left Front Outlet Valve Solenoid Malfunction
C1263 - Right Front Inlet Valve Solenoid Malfunction
C1264 - Right Front Outlet Valve Solenoid Malfunction
C1265 - Left Rear Inlet Valve Solenoid Malfunction
C1266 - Left Rear Outlet Valve Solenoid Malfunction
C1267 - Right Rear Inlet Valve Solenoid Malfunction
C1268 - Right Rear Outlet Valve Solenoid Malfunction
C1271 - Left Front TCS Master Cylinder Isolation Valve Malfunction
C1272 - Left Front TCS Prime Valve Malfunction
C1273 - Right Front TCS Master Cylinder Isolation Valve Malfunction
C1274 - Right Front TCS Prime Valve Malfunction
C1276 - Delivered Torque Signal Circuit Malfunction
C1277 - Requested Torque Signal Circuit Malfunction
C1278 - TCS Temporarily Inhibited By PCM
C1281 - VSES Sensors Uncorrelated
C1282 - Yaw Rate Sensor Bias Circuit Malfunction
C1283 - Excessive Time to Center Steering
C1284 - Lateral Accelerometer Sensor Bias Malfunction
C1285 - Lateral Accelerometer Sensor Circuit Malfunction
C1286 - Steering Sensor Bias Malfunction
C1287 - Steering Sensor Rate Malfunction
C1288 - Steering Sensor Circuit Malfunction
C1291 - Open Brake Lamp Switch Contacts During Deceleration
C1292 - Brake Fluid Pressure Sensor Circuit
C1293 - Code C1291 Set in Previous Ignition Cycle
C1294 - Brake Lamp Switch Circuit Always Active
C1295 - Brake Lamp Switch Circuit Open
C1296 - Brake Fluid Pressure Sensor Circuit
C1297 - PCM Indicated Brake Extended Travel Switch Failure
C1298 - PCM Class 2 Serial Data Link Malfunction
C1326 - Battery Out of Range
C1650 - RSS Control Module Fault
C1658 - RSS Control Module Calibration Fault
C1710 - Left Front Damper Actuator Short Circuit to Battery
C1711 - Left Front Damper Actuator Short Circuit to Ground
C1712 - Left Front Damper Actuator Open Circuit
C1715 - Right Front Damper Actuator Short Circuit to Battery
C1716 - Right Front Damper Actuator Short Circuit to Ground
C1717 - Right Front Damper Actuator Open Circuit
C1720 - Left Rear Damper Actuator Short Circuit to Battery
C1721 - Left Rear Damper Actuator Short Circuit to Ground
C1722 - Left Rear Damper Actuator Open Circuit
C1725 - Right Rear Damper Actuator Short Circuit to Battery
C1726 - Right Rear Damper Actuator Short Circuit to Ground
C1727 - Right Rear Damper Actuator Open Circuit
C1735 - Compressor Relay Short to Battery
C1736 - Compressor Relay Short to GND/Open Circuit
C1737 - Exhaust Solenoid Valve Short to Battery
C1738 - Exhaust Solenoid Valve Short to GND
C1743 - Speed Signal Fault
C1744 - Lift/Dive Signal Discrete Fault
C1760 - Left Front Position Sensor Input Fault
C1761 - Right Front Position Sensor Input Fault
C1762 - Left Rear Position Sensor Input Fault
C1763 - Right Rear Position Sensor Input Fault
C1768 - Position Sensor Supply Fault
C1780 - Loss of Steering Position Signal
C1782 - ICCS2 DL Left Output Short Circuit to Bat
C1783 - ICCS2 DL Left Output Short Circuit to GND
C1784 - ICCS2 DL Right Output Short Circuit to Bat
C1785 - ICCS2 DL Right Output Short Circuit to GND
C1786 - Damper Control Relay Fault
C1787 - Damper Control Relay Short to GND
C1788 - Damper Control Relay Short to Bat
Codee
Post autor: Codee » 07 maja 2010, 19:38
B1200 Climate control push button circuit failure
B1201 Fuel sender circuit failure
B1202 Fuel sender circuit
B1203 Fuel sender circuit
B1204 Fuel sender circuit
B1205 EIC (Electronic Instrument Cluster) switch-1 assembly circuit failure
B1206 EIC switch-1 assembly circuit open
B1207 EIC switch-1 assembly circuit short to battery
B1208 EIC switch-1 assembly circuit short to ground
B1209 EIC switch-2 assembly circuit failure
B1210 EIC switch-2 assembly circuit
B1211 EIC switch-2 assembly circuit
B1212 EIC switch-2 assembly circuit
B1213 Anti-theft number of programmed keys is below minimum
B1214 Running board lamp circuit failure
B1215 Running board lamp circuit short to battery
B1216 Emergency and road side assistance switch short circuit to ground
B1217 Horn relay coil circuit failure
B1218 Horn relay coil circuit short to vbatt
B1219 Fuel tank pressure sensor circuit failure
B1220 Fuel tank pressure sensor circuit open
B1222 Fuel temperature sensor #1 circuit failure
B1223 Fuel temperature sensor #1 circuit open
B1224 Fuel temperature sensor #1 circuit short to battery
B1225 Fuel temperature sensor #1 circuit short to ground
B1226 Fuel temperature sensor #2 circuit failure
B1227 Fuel temperature sensor #2 circuit open
B1228 Fuel temperature sensor #2 circuit short to battery
B1229 Fuel temperature sensor #2 circuit short to ground
B1231 Longitudinal acceleration threshold exceeded
B1232 DO NOT USE???
B1233 Glass break sensor failure
B1234 Mirror switch invalid code
B1235 Window feedback failure
B1236 Window feedback loss of signal
B1237 Window feedback out of range
B1238 Over temperature fault
B1239 Air flow blend door driver circuit failure
B1240 Wiper washer rear pump relay circuit failure
B1241 Wiper washer rear pump relay circuit short to battery
B1242 Air flow recirculation door driver circuit failure
B1243 Express window down switch circuit short to battery
B1244 Wiper rear motor run relay circuit failure
B1245 Wiper rear motor run relay circuit short to battery
B1246 Dim panel potentiometer switch circuit failure
B1247 Panel dim switch circuit open
B1248 Passenger's seatback autoglide rearward switch circuit short to ground
B1249 Blend door failure
B1250 Air temperature internal sensor failure
B1251 Air temperature internal sensor open
B1252 Air temperature internal sensor short to battery
B1253 Air temperature internal sensor short to ground
B1254 Air temperature external sensor failure
B1255 Air temperature external sensor open
B1256 Air temperature external sensor short to battery
B1257 Air temperature external sensor short to ground
B1258 Solar radiation sensor circuit failure
B1259 Solar radiation sensor circuit open
B1260 Solar radiation sensor circuit short to battery
B1261 Solar radiation sensor circuit short to ground
B1262 Servo motor defrost circuit failure
B1263 Servo motor vent circuit failure
B1264 Servo motor foot circuit failure
B1265 Servo motor coolair bypass circuit failure
B1266 Servo motor air intake left circuit failure
B1267 Servo motor air intake right circuit failure
B1268 Servo motor potentiometer defrost circuit failure
B1269 Servo motor potentiometer defrost circuit open
B1270 Servo motor potentiometer defrost circuit short to battery
B1271 Servo motor potentiometer defrost circuit short to ground
B1272 Servo motor potentiometer vent circuit failure
B1273 Servo motor potentiometer vent circuit open
B1274 Servo motor potentiometer vent circuit short to battery
B1275 Servo motor potentiometer vent circuit short to ground
B1276 Servo motor potentiometer foot circuit failure
B1277 Servo motor potentiometer foot circuit open
B1278 Servo motor potentiometer foot circuit short to battery
B1279 Servo motor potentiometer foot circuit short to ground
B1280 Servo motor potentiometer coolair circuit failure
B1281 Servo motor potentiometer coolair circuit open
B1282 Servo motor potentiometer coolair circuit short to battery
B1283 Servo motor potentiometer coolair circuit short to ground
B1284 Servo motor potentiometer airintake left circuit failure
B1285 Servo motor potentiometer airintake left circuit open
B1286 Servo motor potentiometer airintake left circuit short to battery
B1287 Servo motor potentiometer airintake left circuit short to ground
B1288 Servo motor potentiometer airintake right circuit failure
B1289 Servo motor potentiometer airintake right circuit open
B1290 Servo motor potentiometer airintake right circuit short to battery
B1291 Servo motor potentiometer airintake right circuit short to ground
B1292 Battery power relay circuit failure
B1293 Battery power relay circuit open
B1294 Battery power relay circuit short to battery
B1295 Battery power relay circuit short to ground
B1296 Power supply sensor circuit failure
B1297 Power supply sensor circuit open
B1298 Power supply sensor circuit short to battery
B1299 Power supply sensor circuit short to Grodnu
B1232 DO NOT USE???
B1400 Driver power window one touch window relay circuit short to battery
B1401 Driver power window one touch window relay circuit short to ground
B1402 Driver power window down switch circuit failure
B1403 Driver power window up switch circuit failure
B1404 Driver power window down circuit open
B1405 Driver power window down circuit short to battery
B1406 Driver power window down circuit short to ground
B1407 Driver power window up circuit open
B1408 Driver power window up circuit short to battery
B1409 Driver power window up circuit short to ground
B1410 Driver power window motor circuit failure
B1411 Driver power window motor circuit open
B1412 Driver power window motor circuit short to battery
B1413 Driver power window motor circuit short to ground
B1414 Power window LR motor circuit failure
B1415 Power window LR motor circuit open
B1416 Power window LR motor circuit short to battery
B1417 Power window LR motor circuit short to ground
B1418 Passenger power window motor circuit failure
B1419 Passenger power window motor circuit open
B1420 Passenger power window motor circuit short to battery
B1421 Passenger power window motor circuit short to ground
B1422 Power window RR motor circuit failure
B1423 Power window RR motor circuit open
B1424 Power window RR motor circuit short to battery
B1425 Power window RR motor circuit short to ground
B1426 Lamp seat belt circuit short to battery
B1427 Lamp seat belt circuit open
B1428 Lamp seat belt circuit failure
B1429 Lamp seat belt circuit short to ground
B1430 Seat belt switch circuit short to ground
B1431 Wiper brake/run relay circuit failure
B1432 Wiper brake/run relay circuit short to battery
B1433 Wiper brake/run relay circuit short to ground
B1434 Wiper hi/low speed relay coil circuit failure
B1435 Wiper hi/low speed relay coil circuit open
B1436 Wiper hi/low speed relay coil circuit short to battery
B1437 Wiper hi/low speed relay coil circuit short to ground
B1438 Wiper mode select switch circuit failure
B1439 Wiper mode select switch circuit open
B1440 Wiper mode select switch circuit short to battery
B1441 Wiper mode select switch circuit short to ground
B1442 Door handle switch circuit failure
B1443 Door handle switch circuit open
B1444 Door handle switch circuit short to battery
B1445 Door handle switch circuit short to ground
B1446 Wiper park sense circuit failure
B1447 Wiper park sense circuit open
B1448 Wiper park sense circuit short to battery
B1449 Wiper park sense circuit short to ground
B1450 Wiper wash/delay switch circuit failure
B1451 Wiper wash/delay switch circuit open
B1452 Wiper wash/delay switch circuit short to battery
B1453 Wiper wash/delay switch circuit short to ground
B1454 Wiper wash fluid lamp circuit failure
B1455 Wiper wash fluid lamp circuit open
B1456 Wiper wash fluid lamp circuit short to battery
B1457 Wiper wash fluid lamp circuit short to ground
B1458 Wiper washer pump motor relay coil circuit failure
B1459 Wiper washer pump motor relay coil circuit open
B1460 Wiper washer pump motor relay coil circuit short to battery
B1461 Wiper washer pump motor relay coil circuit short to ground
B1462 Seat belt switch circuit failure
B1463 Seat belt switch circuit open
B1464 Seat belt switch circuit short to battery
B1465 Wiper brake/run relay circuit open
B1466 Wiper hi/low speed not switching
B1467 Wiper hi/low speed circuit motor short to battery
B1468 Chime input request circuit failure
B1469 Chime input request circuit open
B1470 Lamp headlamp input circuit failure
B1471 Lamp headlamp input circuit open
B1472 Lamp headlamp input circuit short to ground
B1473 Wiper low speed circuit motor failure
B1474 Battery saver power relay circuit short to battery
B1475 Accessory delay relay contact short to battery
B1476 Wiper high speed circuit motor failure
B1477 Wiper hi/low circuit motor short to ground
B1478 Power window one touch up/down activated simultaneously
B1479 Wiper washerfluid level sensor circuit failure
B1480 Wiper washerfluid level sensor circuit open
B1481 Wiper washerfluid level sensor circuit short to battery
B1482 Wiper washerfluid level sensor circuit short to ground
B1483 Brake pedal input circuit failure
B1484 Brake pedal input circuit open
B1485 Brake pedal input circuit short to battery
B1486 Brake pedal input circuit short to ground
B1487 Door handle right front circuit failure
B1488 Door handle right front circuit open
B1489 Door handle right front circuit short to battery
B1490 Door handle right front circuit short to ground
B1491 Ignition cylinder sensor circuit failure
B1492 Ignition cylinder sensor circuit open
B1493 Ignition cylinder sensor circuit short to battery
B1494 Ignition cylinder sensor circuit short to ground
B1495 Decklid punch-out sensor circuit failure
B1496 Decklid punch-out sensor circuit open
B1497 Decklid punch-out sensor circuit short to battery
B1498 Decklid punch-out sensor circuit short to ground
B1499 Lamp turn signal left circuit failure
B1500 Lamp turn signal left circuit open
B1501 Lamp turn signal left circuit short to battery
B1502 Lamp turn signal left circuit short to ground
B1503 Lamp turn signal right circuit failure
B1504 Lamp turn signal right circuit open
B1505 Lamp turn signal right circuit short to battery
B1506 Lamp turn signal right circuit short to ground
B1507 Flash to pass switch circuit failure
B1508 Flash to pass switch circuit open
B1509 Flash to pass switch circuit short to battery
B1510 Flash to pass switch circuit short to ground
B1511 Driver door handle circuit failure
B1512 Driver door handle circuit open
B1513 Driver door handle circuit short to battery
B1514 Driver door handle circuit short to ground
B1515 Driver seat occupied switch circuit failure
B1516 Driver seat occupied switch circuit open
B1517 Driver seat occupied switch circuit short to battery
B1518 Driver seat occupied switch circuit short to ground
B1519 Hood switch circuit failure
B1520 Hood switch circuit open
B1521 Hood switch circuit short to battery
B1522 Hood switch circuit short to ground
B1523 Keyless entry circuit failure
B1524 Keyless entry circuit open
B1525 Keyless entry circuit short to battery
B1526 Keyless entry circuit short to ground
B1527 Memory set switch circuit failure
B1528 Memory set switch circuit open
B1529 Memory set switch circuit short to battery
B1530 Memory set switch circuit short to ground
B1531 Memory 1 switch circuit failure
B1532 Memory 1 switch circuit open
B1533 Memory 1 switch circuit short to battery
B1534 Memory 1 switch circuit short to ground
B1535 Memory 2 switch circuit failure
B1536 Memory 2 switch circuit open
B1537 Memory 2 switch circuit short to battery
B1538 Memory 2 switch circuit short to ground
B1539 Mirror driver switch assembly circuit failure
B1540 Mirror driver switch assembly circuit open
B1541 Mirror driver switch assembly circuit short to battery
B1542 Mirror driver switch assembly circuit short to ground
B1543 Seat direction switch assembly circuit failure
B1544 Seat direction switch assembly circuit open
B1545 Seat direction switch assembly circuit short to battery
B1546 Seat direction switch assembly circuit short to ground
B1547 Power window master circuit failure
B1548 Power window master circuit open
B1549 Power window master circuit short to battery
B1550 Power window master circuit short to ground
B1551 Decklid release circuit failure
B1552 Decklid release circuit open
B1553 Decklid release circuit short to battery
B1554 Decklid release circuit short to ground
B1555 Ignition run/start circuit failure
B1556 Ignition run/start circuit open
B1557 Ignition run/start circuit short to battery
B1558 Ignition run/start circuit short to ground
B1559 Door lock cylinder circuit failure
B1560 Door lock cylinder circuit open
B1561 Door lock cylinder circuit short to battery
B1562 Door lock cylinder circuit short to ground
B1563 Door ajar circuit failure
B1564 Door ajar circuit open
B1565 Door ajar circuit short to battery
B1566 Door ajar circuit short to ground
B1567 Lamp headlamp high-beam circuit failure
B1568 Lamp headlamp high-beam circuit open
B1569 Lamp headlamp high-beam circuit short to battery
B1570 Lamp headlamp high-beam circuit short to ground
B1571 Door ajar LR circuit failure
B1572 Door ajar LR circuit open
B1573 Door ajar LR circuit short to battery
B1574 Door ajar LR circuit short to ground
B1575 Lamp park input circuit failure
B1576 Lamp park input circuit open
B1577 Lamp park input circuit short to battery
B1578 Lamp park input circuit short to ground
B1579 Dim panel increase input circuit failure
B1580 Dim panel increase input circuit open
B1581 Dim panel increase input circuit short to battery
B1582 Dim panel increase input circuit short to ground
B1583 Dim panel decrease input circuit failure
B1584 Dim panel decrease input circuit open
B1585 Dim panel decrease input circuit short to battery
B1586 Dim panel decrease input circuit short to ground
B1587 Autolamp delay increase circuit failure
B1588 Autolamp delay increase circuit open
B1589 Autolamp delay increase circuit short to battery
B1590 Autolamp delay increase circuit short to ground
B1591 Autolamp delay decrease circuit failure
B1592 Autolamp delay decrease circuit open
B1593 Autolamp delay decrease circuit short to battery
B1594 Autolamp delay decrease circuit short to ground
B1595 Ignition switch illegal input code
B1596 Service continuous codes
B1597 Driver's seat seatback autoglide forward switch circuit short to ground
B1598 Driver's seat seatback autoglide rearward switch circuit short to ground
B1599 Passenger's seat seatback autoglide forward switch circuit short to Grodnu
B1600 PATS (Passive Anti-Theft System) ignition key transponder signal is not received
B1601 PATS received incorrect key-code from ignition key transponder
B1602 PATS received invlaid format of key-code from ignition key transpnder
B1603 Anti-theft indicator lamp circuit failure
B1604 Anti-theft indicator lamp circuit open
B1605 Anti-theft indicator lamp circuit short to battery
B1606 Anti-theft indicator lamp circuit short to ground
B1607 Illuminated entry input circuit failure
B1608 Illuminated entry input circuit open
B1609 Illuminated entry input circuit short to battery
B1610 Illuminated entry input circuit short to ground
B1611 Wiper rear mode select switch circuit failure
B1612 Wiper rear mode select switch circuit open
B1613 Wiper rear mode select switch circuit short to battery
B1614 Wiper rear mode select switch circuit short to ground
B1615 Wiper rear disable switch circuit failure
B1616 Wiper rear disable switch circuit open
B1617 Wiper rear disable switch circuit short to battery
B1618 Wiper rear disable switch circuit short to ground
B1619 Wiper rear low limit inout circuit failure
B1620 Wiper rear low limit inout circuit open
B1621 Wiper rear low limit inout circuit short to battery
B1622 Wiper rear low limit inout circuit short to ground
B1623 Lamp keypad output circuit failure
B1624 Lamp keypad output circuit open
B1625 Lamp keypad output circuit short to battery
B1626 Lamp keypad output circuit short to ground
B1627 PRNDL reverse input circuit failure
B1628 PRNDL reverse input circuit open
B1629 PRNDL reverse input circuit short to battery
B1630 PRNDL reverse input circuit short to ground
B1631 Mirror driver left circuit failure
B1632 Mirror driver left circuit open
B1633 Mirror driver left circuit short to battery
B1634 Mirror driver left circuit short to ground
B1635 Mirror driver right circuit failure
B1636 Mirror driver right circuit open
B1637 Mirror driver right circuit short to battery
B1638 Mirror driver right circuit short to ground
B1639 Mirror passenger left circuit failure
B1640 Mirror passenger left circuit open
B1641 Mirror passenger left circuit short to battery
B1642 Mirror passenger left circuit short to ground
B1643 Mirror passenger right circuit failure
B1644 Mirror passenger right circuit open
B1645 Mirror passenger right circuit short to battery
B1646 Mirror passenger right circuit short to ground
B1647 Seat driver recline forward circuit failure
B1648 Seat driver recline forward circuit open
B1649 Seat driver recline forward circuit short to battery
B1650 Seat driver recline forward circuit short to ground
B1651 Seat driver recline backward circuit failure
B1652 Seat driver recline backward circuit open
B1653 Seat driver recline backward circuit short to battery
B1654 Seat driver recline backward circuit short to ground
B1655 Seat driver rear up circuit failure
B1656 Seat driver rear up circuit open
B1657 Seat driver rear up circuit short to battery
B1658 Seat driver rear up circuit short to ground
B1659 Seat driver front up circuit failure
B1660 Seat driver front up circuit open
B1661 Seat driver front up circuit short to battery
B1662 Seat driver front up circuit short to ground
B1663 Seat driver front up/down motor stalled
B1664 Seat driver rear up/down motor stalled
B1665 Seat driver front forward/backward motor stalled
B1666 Seat driver recline motor stalled
B1667 Mirror driver up/down motor stalled
B1668 Mirror driver right/left motor stalled
B1669 Mirror passenger up/down motor stalled
B1670 Mirror passenger right/left motor stalled
B1671 Battery module voltage out of range
B1672 Seat driver occupied input circuit failure
B1673 Seat driver occupied input circuit open
B1674 Seat driver occupied input circuit short to battery
B1675 Seat driver occupied input circuit short to ground
B1676 Battery pack voltage out of range
B1677 Alarm panic input circuit failure
B1678 Alarm panic input circuit open
B1679 Alarm panic input circuit short to battery
B1680 Alarm panic input circuit short to ground
B1681 PATS transceiver module signal is not received
B1682 PATS is disabled (check link between PATS & transponder)
B1683 Mirror driver/passenger switch circuit failure
B1684 Mirror driver/passenger switch circuit open
B1685 Lamp dome input circuit failure
B1686 Lamp dome input circuit open
B1687 Lamp dome input circuit short to battery
B1688 Lamp dome input circuit short to ground
B1689 Autolamp delay circuit failure
B1690 Autolamp delay circuit open
B1691 Autolamp delay circuit short to battery
B1692 Autolamp delay circuit short to ground
B1693 Autolamp on circuit failure
B1694 Autolamp on circuit open
B1695 Autolamp on circuit short to battery
B1696 Autolamp on circuit short to ground
B1697 Mirror driver/passenger switch circuit short to battery
B1698 Mirror driver/passenger switch circuit short to ground
B1699 Passenger seat occupied switch circuit short to ground
Codee
Post autor: Codee » 07 maja 2010, 19:40
B1700 Passenger seatbelt tension reducer circuit short to ground
B1701 Seat driver recline forward switch circuit failure
B1702 Seat driver recline forward switch circuit open
B1703 Seat driver recline forward switch circuit short to battery
B1704 Seat driver recline forward switch circuit
B1705 Seat driver recline rearward switch circuit failure
B1706 Seat driver recline rearward switch circuit open
B1707 Seat driver recline rearward switch circuit short to battery
B1708 Seat driver recline rearward switch circuit short to ground
B1709 Seat driver front up switch circuit failure
B1710 Seat driver front up switch circuit open
B1711 Seat driver front up switch circuit short to battery
B1712 Seat driver front up switch circuit short to ground
B1713 Seat driver front down switch circuit failure
B1714 Seat driver front down switch circuit open
B1715 Seat driver front down switch circuit short to battery
B1716 Seat driver front down switch circuit short to ground
B1717 Seat driver forward switch circuit failure
B1718 Seat driver forward switch circuit open
B1719 Seat driver forward switch circuit short to battery
B1720 Seat driver forward switch circuit short to ground
B1721 Seat driver rearward switch circuit failure
B1722 Seat driver rearward switch circuit open
B1723 Seat driver rearward switch circuit short to battery
B1724 Seat driver rearward switch circuit short to ground
B1725 Seat driver rear up switch circuit failure
B1726 Seat driver rear up switch circuit open
B1727 Seat driver rear up switch circuit short to battery
B1728 Seat driver rear up switch circuit short to ground
B1729 Seat driver rear down switch circuit failure
B1730 Seat driver rear down switch circuit open
B1731 Seat driver rear down switch circuit short to battery
B1732 Seat driver rear down switch circuit short to ground
B1733 Mirror driver vertical switch circuit failure
B1734 Mirror driver vertical switch circuit open
B1735 Mirror driver vertical switch circuit short to battery
B1736 Mirror driver vertical switch circuit short to ground
B1737 Mirror driver horizontal switch circuit failure
B1738 Mirror driver horizontal switch circuit open
B1739 Mirror driver horizontal switch circuit short to battery
B1740 Mirror driver horizontal switch circuit short to ground
B1741 Mirror passenger vertical switch circuit failure
B1742 Mirror passenger vertical switch circuit open
B1743 Mirror passenger vertical switch circuit short to battery
B1744 Mirror passenger vertical switch circuit short to ground
B1745 Mirror passenger horizontal switch circuit failure
B1746 Mirror passenger horizontal switch circuit open
B1747 Mirror passenger horizontal switch circuit short to battery
B1748 Mirror passenger horizontal switch circuit short to ground
B1749 Park/neutral switch circuit failure
B1750 Park/neutral switch circuit open
B1751 Park/neutral switch circuit short to battery
B1752 Park/neutral switch circuit short to ground
B1753 Hazard flash output circuit failure
B1754 Hazard flash output circuit open
B1755 Hazard flash output circuit short to battery
B1756 Hazard flash output circuit short to ground
B1757 Seat driver rear down circuit failure
B1758 Seat driver rear down circuit open
B1759 Seat driver rear down circuit short to battery
B1760 Seat driver rear down circuit short to ground
B1761 Seat driver front down circuit failure
B1762 Seat driver front down circuit open
B1763 Seat driver front down circuit short to battery
B1764 Seat driver front down circuit short to ground
B1765 Seat driver forward circuit failure
B1766 Seat driver forward circuit open
B1767 Seat driver forward circuit short to battery
B1768 Seat driver forward circuit short to ground
B1769 Seat driver backward circuit failure
B1770 Seat driver backward circuit open
B1771 Seat driver backward circuit short to battery
B1772 Seat driver backward circuit short to ground
B1773 Mirror driver up circuit failure
B1774 Mirror driver up circuit open
B1775 Mirror driver up circuit short to battery
B1776 Mirror driver up circuit short to ground
B1777 Driver seatbelt tension reducer circuit short to ground
B1778 Mirror driver down circuit failure
B1779 Mirror driver down circuit open
B1780 Mirror driver down circuit short to battery
B1781 Mirror driver down circuit short to ground
B1782 Mirror passenger up circuit failure
B1783 Mirror passenger up circuit open
B1784 Mirror passenger up circuit short to battery
B1785 Mirror passenger up circuit short to ground
B1786 Mirror passenger down circuit failure
B1787 Mirror passenger down circuit open
B1788 Mirror passenger down circuit short to battery
B1789 Mirror passenger down circuit short to ground
B1790 Autolamp sensor input circuit failure
B1791 Autolamp sensor input circuit open
B1792 Autolamp sensor input circuit short to battery
B1793 Autolamp sensor input circuit short to ground
B1794 Lamp headlamp low/beam circuit failure
B1795 Lamp headlamp low/beam circuit open
B1796 Lamp headlamp low/beam circuit short to battery
B1797 Lamp headlamp low/beam circuit short to ground
B1798 Lamp turn signal front output circuit failure
B1799 Lamp turn signal front output circuit open
B1800 Lamp turn signal front output circuit short to battery
B1801 Lamp turn signal front output circuit short to ground
B1802 Lamp turn signal rear output circuit failure
B1803 Lamp turn signal rear output circuit open
B1804 Lamp turn signal rear output circuit short to battery
B1805 Lamp turn signal rear output circuit short to ground
B1806 Lamp tail output circuit failure
B1807 Lamp tail output circuit open
B1808 Lamp tail output circuit short to battery
B1809 Lamp tail output circuit short to ground
B1810 Lamp backup switch input circuit failure
B1811 Lamp backup switch input circuit open
B1812 Lamp backup switch input circuit short to battery
B1813 Lamp backup switch input circuit short to ground
B1814 Wiper rear motor down relay coil circuit failure
B1815 Wiper rear motor down relay coil circuit open
B1816 Wiper rear motor down relay coil circuit short to battery
B1817 Wiper rear motor down relay coil circuit short to ground
B1818 Wiper rear motor up relay coil circuit failure
B1819 Wiper rear motor up relay coil circuit open
B1820 Wiper rear motor up relay coil circuit short to battery
B1821 Wiper rear motor up relay coil circuit short to ground
B1822 Wiper rear park sense input circuit failure
B1823 Wiper rear park sense input circuit open
B1824 Wiper rear park sense input circuit short to battery
B1825 Wiper rear park sense input circuit short to ground
B1826 Wiper rear high limit input circuit failure
B1827 Wiper rear high limit input circuit open
B1828 Wiper rear high limit input circuit short to battery
B1829 Wiper rear high limit input circuit short to ground
B1830 Door unlock disarm switch circuit failure
B1831 Door unlock disarm switch circuit open
B1832 Door unlock disarm switch circuit short to battery
B1833 Door unlock disarm switch circuit short to ground
B1834 Door unlock disarm output circuit failure
B1835 Door unlock disarm output circuit open
B1836 Door unlock disarm output circuit short to battery
B1837 Door unlock disarm output circuit short to ground
B1838 Battery saver power relay circuit failure
B1839 Wiper rear motor circuit failure
B1840 Wiper front power circuit failure
B1841 Wiper front power circuit open
B1842 Wiper front power circuit short to battery
B1843 Wiper front power circuit short to ground
B1844 Phone handset circuit failure
B1845 Ignition tamper circuit failure
B1846 Ignition tamper circuit open
B1847 Ignition tamper circuit short to battery
B1848 Ignition tamper circuit short to ground
B1849 Climate control temperature differential circuit failure
B1850 Climate control temperature differential circuit open
B1851 Climate control temperature differential circuit short to battery
B1852 Climate control temperature differential circuit short to ground
B1853 Climate control air temperature internal sensor motor circuit failure
B1854 Climate control air temperature internal sensor motor circuit open
B1855 Climate control air temperature internal sensor motor circuit short to battery
B1856 Climate control air temperature internal sensor motor circuit short to ground
B1857 Climate control on/off switch circuit failure
B1858 Climate control A/C pressure swiitch circuit failure
B1859 Climate control A/C pressure swiitch circuit open
B1860 Climate control A/C pressure swiitch circuit short to battery
B1861 Climate control A/C pressure swiitch circuit short to ground
B1862 Climate control A/C lock sensor failure
B1863 Ground ECU circuit open
B1864 Battery power supply ECU circuit failure
B1865 Battery power supply ECU circuit open
B1866 Battery power supply ECU circuit short to battery
B1867 Battery power supply ECU circuit short to ground
B1868 Lamp air bag warning indicator circuit failure
B1869 Lamp air bag warning indicator circuit open
B1870 Lamp air bag warning indicator circuit short to battery
B1871 Passenger air bag disable module fault
B1872 Turn signal / hazard power feed circuit short to battery
B1873 Turn signal / hazard power feed circuit short to ground
B1874 Cellular phone handset not present
B1875 Turn signal / hazard power feed circuit failure
B1876 Seatbelt driver pretensioner circuit failure
B1877 Seatbelt driver pretensioner circuit
B1878 Seatbelt driver pretensioner circuit
B1879 Seatbelt driver pretensioner circuit
B1880 Seatbelt passenger pretensioner circuit failure
B1881 Seatbelt passenger pretensioner circuit
B1882 Seatbelt passenger pretensioner circuit
B1883 Seatbelt passenger pretensioner circuit
B1884 PAD warning lamp inoperative
B1885 Seatbelt driver pretensioner circuit resistance low on squib
B1886 Seatbelt passenger pretensioner circuit resistance low on squib
B1887 Air bag driver circuit resistance low or shorted together
B1888 Air bag passenger circuit resistance low or shorted together
B1889 Passenger airbag disable module sensor obstructed
B1890 PAD warning lamp circuit short to battery
B1891 Air bag tone warning indicator circuit short to battery
B1892 Air bag tone warning indicator circuit failure
B1893 GPS (Global Positioning System) antenna open circuit
B1894 Wiper rear motor speed sense circuit failure
B1895 Driver/passenger door ajar output circuit failure
B1896 Driver/passenger door ajar output circuit short to battery
B1897 Horn switch circuit failure
B1898 Chime input #2 circuit short to ground
B1899 Microphone input signal circuit open
B1900 Driver side airbag fault
B1901 Air bag crash sensor #1 feed/return circuit short to ground
B1902 Air bag crash sensor #1 ground circuit failure
B1903 Air bag crash sensor #1 ground circuit short to battery
B1904 Air bag crash sensor #2 feed/return circuit failure
B1905 Air bag crash sensor #2 feed/return circuit short to battery
B1906 Air bag crash sensor #2 feed/return circuit short to ground
B1907 Air bag crash sensor #2 ground circuit failure
B1908 Air bag crash sensor #2 ground circuit short to battery
B1909 Air bag crash sensor #2 ground circuit short to ground
B1910 Air bag diagnostic monitor ground circuit failure
B1911 Air bag diagnostic monitor ground circuit short to battery
B1912 Air bag diagnostic monitor ground circuit short to gound
B1913 Air bag driver/passenger circuit short to ground
B1914 Air bag crash sensor #1 / #2 short circuit to ground
B1915 Air bag driver circuit failure
B1916 Air bag driver circuit short to battery
B1917 Air bag memory clear circuit failure
B1918 Air bag memory clear circuit open
B1919 Air bag memory clear circuit short to battery
B1920 Air bag passenger circuit failure
B1921 Air bag diagnostic monitor ground circuit open
B1922 Air bag safing sensor output circuit short to battery
B1923 Air bag memory clear circuit short to ground
B1924 Air bag internal diagnostic monitor fault or system disarm fault
B1925 Air bag passenger circuit short to battery
B1926 Air bag passenger pressure switch circuit failure
B1927 Passenger side aribag fault
B1928 Air bag safing sensor output circuit failure
B1929 Air bag safing sensor output circuit open
B1930 Air bag safing sensor output circuit short to ground
B1931 Air bag crash sensor #1 feed/return circuit failure
B1932 Air bag driver circuit open
B1933 Air bag passenger circuit open
B1934 Air bag driver inflator circuit resistance low on squib
B1935 Air bag passenger inflator circuit resistance low on squib
B1936 Air bag driver circuit short to ground
B1937 Air bag passenger pressure switch circuit open
B1938 Air bag passenger circuit short to ground
B1939 Air bag passenger pressure switch circuit short to ground
B1941 Air bag crash sensor #1 feed/return circuit open
B1942 Air bag crash sensor #2 feed/return circuit open
B1943 Air bag crash sensor #1 ground circuit short to ground
B1944 Air bag crash sensor #1 ground circuit open
B1945 Air bag crash sensor #2 ground circuit open
B1946 Climate control A/C post evaporator sensor circuit failure
B1947 Climate control A/C post evaporator sensor circuit short to ground
B1948 Climate control water temperature sensor circuit failure
B1949 Climate control water temperature sensor circuit short to ground
B1950 Rear seat up/down potentiometer feedback circuit failure
B1951 Rear seat up/down potentiometer feedback circuit open
B1952 Rear seat up/down potentiometer feedback circuit short to battery
B1953 Rear seat up/down potentiometer feedback circuit short to ground
B1954 Rear seat up/down potentiometer feedback circuit failure
B1955 Rear seat up/down potentiometer feedback circuit open
B1956 Rear seat up/down potentiometer feedback circuit short to battery
B1957 Rear seat up/down potentiometer feedback circuit short to ground
B1958 Seat recline forward/backward potentiometer feedback circuit failure
B1959 Seat recline forward/backward potentiometer feedback circuit open
B1960 Seat recline forward/backward potentiometer feedback circuit short to battery
B1961 Seat recline forward/backward potentiometer feedback circuit short to ground
B1962 Seat horizontal forward/rearward potentiometer feedback circuit failure
B1963 Seat horizontal forward/rearward potentiometer feedback circuit open
B1964 Seat horizontal forward/rearward potentiometer feedback circuit short to battery
B1965 Seat horizontal forward/rearward potentiometer feedback circuit short to ground
B1966 A/C post heater sensor circuit failure
B1967 A/C post heater sensor circuit short to ground
B1968 A/C water pump detection circuit failure
B1969 A/C clutch magnetic control circuit failure
B1970 Passenger seatback forward switch circuit short to ground
B1971 Passenger seatback rearward switch circuit short to ground
B1972 Passenger rear seat up switch circuit short to battery
B1973 Passenger rear seat down switch circuit short to battery
B1974 Passenger seat recline forward switch circuit short to battery
B1975 Passenger seat recline back switch circuit short to battery
B1976 Passenger seat forward switch circuit short to battery
B1977 Passenger front seat up switch circuit short to battery
B1978 Passenger front seat down switch circuit short to battery
B1979 Passenger front seat rearward switch circuit short to battery
B1980 Bulb - outage condition detected
B1981 Memory off switch circuit short to battery
B1982 Driver door unlock relay circuit failure
B1983 Driver door unlock relay circuit short to battery
B1984 Seat switch lumbar inflate circuit failure
B1985 Seat switch lumbar deflate circuit failure
B1986 Driver seat seatback autoglide rearward switch circuit failure
B1988 Pedal position forward switch circuit short to battery
B1989 Pedal position rearward switch circuit short to battery
B1990 Pedal forward/rearward potentiometer feedback circuit failure
B1991 Pedal forward/rearward potentiometer feedback circuit short to battery
B1992 Driver side, side mount airbag circuit short to vbatt
B1993 Driver side, side mount airbag circuit short to ground
B1994 Driver side, side mount airbag circuit open
B1995 Driver side, side mount airbag low resistance on squib
B1996 Passenger side, side mount airbag circuit short to vbatt
B1997 Passenger side, side mount airbag circuit short to ground
B1998 Passenger side, side mount airbag circuit open
B1999 Passenger side, side mount airbag low resistance on squib
B2100 Door driver key cylinder switch failure
B2101 Head rest switch circuit failuire
B2102 Antenna circuit short to ground
B2103 Antenna not connected
B2104 Door passenger key cylinder switch failure
B2105 Throttle position input out of range low
B2106 Throttle position input out of range high
B2107 Front wiper motor relay circuit short to vbatt
B2108 Trunk key cylinder switch failure
B2109 Heated windscreen relay short to vbatt
B2110 Front wiper motor relay circuit open
B2111 All door lock input short to ground
B2112 Door driver set switch stuck failure
B2113 Heated windsheild input short to ground
B2114 Front washer input short to ground
B2115 Rear washer input short to ground
B2116 Door driver reset switch stuck failure
B2117 Driver side, side mount airbag low capacitance on squib
B2118 Passenger side, side mount airbag low capacitance on squib
B2119 Compressor failure
B2120 Door passenger set switch stuck failure
B2122 Driver side satellite communication circuit short to ground
B2123 Passenger side satellite communication circuit short to ground
B2124 Door passenger reset switch stuck failure
B2128 Central lock motor failure
B2129 Central lock feedback failure
B2130 Double lock timeout failure
B2131 Double lock feedback failure
B2132 Dimmer switch circuit short to ground
B2133 Brake motor warning lamp circuit failure
B2134 Brake motor warning lamp circuit short to vbatt
B2135 Park brake applied warning lamp circuit failure
B2136 Park brake applied warning lamp circuit short to battery
B2139 Data mismatch between PCM and PATS/instrument cluster
B2141 NVM (Non-Volatile Memory) configuration failure
B2142 NVM TIC (Transmitter ID Code) failure
B2143 NVM memory failure
B2144 NVM alarm data failure
B2145 NVM RF HR failure
B2146 Seat recline motor position out of range
B2148 PWM (Pulse Width Modulation) input circuit failure
B2149 Seat front vertical motor position out of range
B2150 power supply #1 circuit short to ground
B2151 power supply #1 circuit short to ground
B2152 Seat rear vertical motor position out of range
B2153 Rear echo sensor circuit failure
B2154 Front echo sensor circuit failure
B2155 Seat horizontal position out of range
B2156 Rear doppler sensor circuit failure
B2157 Front doppler sensor circuit failure
B2158 Seat recline motor memory position out of range
B2159 Memory #1 output short to ground
B2160 Memory #1 output short to battery
B2161 Seat front vertical motor memory position out of range
B2162 Data mismatch #2
B2163 Clutch position fault
B2164 Seat rear vertical motor memory position out of range
B2165 Gear shift position fault
B2166 Gear select position fault
B2167 Seat horizontal motor memory position out of range
B2168 Unable to confirm lock condition
B2169 Unable to confirm unlock condition
B2170 Steering column lock switch circuit failure
B2172 Inertia switch input circuit open
B2174 Window driver rear remote up switch short to battery
B2175 A/C request signal circuit short to ground
B2176 Overdrive switch circuit short to battery
B2177 Interior scanning sensor circuit failure
B2178 Window driver rear remote down switch short to battery
B2179 Front wiper select switch "A" short to ground
B2180 Front wiper select switch "B" short to ground
B2181 Front wiper select switch "C" short to ground
B2182 Window passenger front remote up switch short to battery
B2183 Front wiper select switch "H" short to ground
B2184 Front wiper select switch "W" short to ground
B2185 Front wiper select switch "D" short to ground
B2186 Window passenger front remote down switch short to battery
B2187 Front wiper select switch "B" short to ground
B2188 Front wiper select switch "E" short to ground
B2190 Window passenger rear remote up switch short to battery
B2194 Window passenger rear remote down switch short to battery
B2195 Driver window up/down power circuit short to ground
B2196 Passenger window up/down power circuit short to ground
B2197 TV module error
B2198 Trafficmaster module error
B2199 VICS (Vehicle Information and Communication System) module terror
B2200 No communication to TV module (no fitting of TV)
B2201 No communication with Traffic Master module
B2202 No communication to VICS module (no fitting of VICS)
B2203 CD-ROM error
B2204 GPS antenna connection open or short
B2205 GPS recieve error
B2206 Gyroscope error
B2207 ECU ROM checksum error
B2208 Communication link to display and switch module error
B2209 Interior lamp override switch open circuit
B2210 Interior lamp override switch short to ground
B2211 Low coolant lamp output circuit short to battery
B2214 Window passenger front up switch short to battery
B2215 Window passenger front down switch short to battery
B2219 Window driver front current feedback exceeded
B2220 Window driver rear current feedback exceeded
B2221 Window passenger front current feedback exceeded
B2222 Window passenger rear current feedback exceeded
B2223 Driver mirror drive circuit failure
B2224 Passenger mirror drive circuit failure
B2225 Front crash sensor mount fault
B2226 Front crash sensor internal fault
B2227 Front crash sensor driver communications fault
B2228 Air bag driver circuit short to ground - loop #2
B2229 Air bag passenger circuit short to ground - loop #2
B2230 Air bag driver circuit short to battery - loop #2
B2231 Air bag passenger circuit short to battery - loop #2
B2232 Driver airbag open circuit - loop #2
B2233 Passenger airbag open circuit - loop #2
B2234 Air bag driver inflator circuit resistance low on squib - loop #2
B2235 Air bag passenger inflator circuit resistance low on squib - loop #2
B2236 Weak or defected electric vehicle battery module fault
B2237 Vehicle signal indicating park while VSS (Vehicle Speed Signal) present
B2238 Power cable for power sliding door broken
B2239 Rear cargo door set switch stuck (short to ground)
B2240 Rear cargo door reset switch stuck (short to ground)
B2241 Rear cargo door lock circuit short to ground
B2242 Rear cargo door unlock circuit open
B2243 Driver rear door ajar circuit open
B2244 Driver sliding door ajar circuit short to ground
B2245 Passenger rear door ajar circuit open
B2246 Passenger sliding door ajar circuit short to ground
B2247 EV (Electric Vehicle) battery pack temperature fault
B2248 Heated windsheild relay coil circuit failure
B2249 Head lamp relay coil short to battery
B2250 All doors unlock relay circuit failure
B2251 Parklamp output relay driver circuit failure
B2252 Parklamp output relay driver short to battery
B2300 Seat driver memory position error
B2301 Seat passenger memory position error
B2302 Seat headrest feedback potentiometer circuit failure
B2303 Seat headrest feedback potentiometer circuit open
B2304 Seat headrest feedback potentiometer circuit short to battery
B2305 Seat headrest feedback potentiometer circuit short to ground
B2306 Seat headrest motor stalled
B2310 Mirror driver memory position error
B2311 Mirror passenger memory position error
B2312 Mirror passenger horizontal feedback potentiometer circuit failure
B2313 Mirror passenger horizontal feedback potentiometer circuit open
B2314 Mirror passenger horizontal feedback potentiometer circuit short to battery
B2315 Mirror passenger horizontal feedback potentiometer circuit short to ground
B2316 Mirror passenger vertical feedback potentiometer circuit failure
B2317 Mirror passenger vertical feedback potentiometer circuit open
B2318 Mirror passenger vertical feedback potentiometer circuit short to battery
B2319 Mirror passenger vertical feedback potentiometer circuit short to ground
B2320 Mirror driver horizontal feedback potentiometer circuit failure
B2321 Mirror driver horizontal feedback potentiometer circuit open
B2322 Mirror driver horizontal feedback potentiometer circuit short to battery
B2323 Mirror driver horizontal feedback potentiometer circuit short to ground
B2324 Mirror driver vertical feedback potentiometer circuit failure
B2325 Mirror driver vertical feedback potentiometer circuit open
B2326 Mirror driver vertical feedback potentiometer circuit short to battery
B2327 Mirror driver vertical feedback potentiometer circuit short to ground
B2328 Column reach feedback potentiometer circuit failure
B2329 Column reach feedback potentiometer circuit open
B2330 Column reach feedback potentiometer circuit short to battery
B2331 Column reach feedback potentiometer circuit short to ground
B2332 Column tilt feedback potentiometer circuit failure
B2333 Column tilt feedback potentiometer circuit open
B2334 Column tilt feedback potentiometer circuit short to battery
B2335 Column tilt feedback potentiometer circuit short to ground
B2336 Mirror switch assembly circuit failure
B2337 Mirror switch assembly circuit open
B2338 Mirror switch assembly circuit short to battery
B2339 Mirror switch assembly circuit short to ground
B2340 Column reach motor stalled
B2341 Column tilt motor stalled
B2342 Seat switch reference voltage positive common open circuit
B2343 Seat switch reference voltage positive common supply low voltage
B2344 Seat switch reference voltage positive common supply voltage fault
B2345 Seat switch reference voltage negative common open circuit
B2346 Mirror switch reference voltage positive common open circuit
B2347 Mirror switch reference voltage positive common supply low voltage
B2348 Mirror switch reference voltage positive common supply voltage fault
B2349 Mirror switch reference voltage negative common open circuit
B2350 Steering column switch circuit short to battery
B2351 Steering column switch circuit failure
B2352 Driver memory power switch indicator circuit short to battery
B2353 Driver mirror power driver circuit short ground
B2354 Driver mirror hoizontal/vertical feedback potentiometer circuit open
B2355 Passenger mirror hoizontal/vertical feedback potentiometer circuit open
B2357 Driver window down current sense low circuit failure
B2362 Remote open/close signal circuit short to ground
B2363 Optical sensor system failure
B2364 Fuel filler door open circuit
B2365 B-pillar power sliding door open/close switch input circuit short to ground
B2366 IP power sliding door open/close switch circuit short to ground
B2367 Power sliding door override switch input circuit short to ground
B2368 Steering column switch circuit out of range
B2369 Chime output request circuit short to ground
B2373 LED #1 circuit short to ground
B2374 Power sliding detent (latch) circuit failure
B2380 Heater coolant temperature sensor circuit short to ground
B2381 Heater coolant temperature sensor circuit open
B2384 Audio reverse aid mute input circuit failure
B2385 Audio navigation mute input circuit failure
B2401 Audio tape deck mechanism fault
B2402 Audio CD/DJ thermal shutdown fault
B2403 Audio CD/DJ internal fault
B2404 Audio steering wheel switch circuit fault
B2405 Audio single disc CD player thermal shutdown fault
B2406 Audio single disc CD player internal fault
B2416 Climate control recirculation actuator out of limits
B2425 Remote keyless entry out of synchronization
B2426 Passenger solar radiation sensor circuit open
B2427 Passenger solar radiation sensor circuit short to ground
B2428 A/C post heater sensor #2 circuit failure
B2429 A/C post heater sensor #2 circuit short to ground
B2431 Transponder programming failed
B2432 Driver's seat belt buckle switch circuit open
B2433 Driver's seat belt buckle switch circuit short to battery
B2434 Driver's seat belt buckle switch circuit short to ground
B2435 Driver's seat belt buckle switch circuit resistance out of range
B2436 Passenger's seat belt buckle switch circuit open
B2437 Passenger's seat belt buckle switch circuit short to battery
B2438 Passenger's seat belt buckle switch circuit short to ground
B2439 Passenger's seat belt buckle switch circuit resistance out of range
B2440 Passenger side, side crash sensor mount fault
B2441 Driver side, side crash sensor mount fault
B2442 Intrusion sensor fault
B2443 Powertrain performance mode switch circuit failure
B2444 Driver side crash sensor internal fault
B2445 Passenger side crash sensor internal fault
B2446 RESCU/VEMS (Vehicle Emergency Messaging System) input circuit open
B2447 RESCU/VEMS (Vehicle Emergency Messaging System) input short to battery
B2448 RESCU/VEMS (Vehicle Emergency Messaging System) input short to ground
B2449 Aux heater glow plug circuit short to ground
B2450 Aux heater glow plug circuit open
B2451 Aux heater fuel pump circuit short to ground
B2452 Aux heater fuel pump circuit open
B2453 Aux heater blower fan circuit short to ground
B2454 Aux heater blower fan circuit open
B2455 Aux heater blower faulted
B2456 Aux heater coolant sensor cicuit short to ground
B2457 Aux heater coolant sensor cicuit open
B2458 Aux heater overheat sensor circuit short to ground
B2459 Aux heater overheat sensor circuit open
B2460 Aux heater flame sensor circuit short to ground
B2461 Aux heater flame sensor circuit open
B2462 Aux heater flame out fault
B2463 Aux heater overheat fault
B2464 Aux heater start time exceeded
B2465 Aux heater start counter overrun/system locked
B2466 Aux heater overheat counter overrun/system locked
B2467 Aux heater coll down time exceeded
B2468 Aux heater coolant pump circuit short to ground
B2469 Aux heater coolant pump circuit open
B2470 Interior fan control circuit short to ground
B2471 Interior fan control circuit open
B2472 Fog lamp switch failure
B2473 Passenger door disarm switch circuit failure
B2474 Passenger door lock switch circuit short to ground
B2475 Passenger door unlock switch circuit short to ground
B2476 Radio present switch circuit failure
B2477 Module configuration failure
B2478 Anti theft input signal short to ground
B2479 Brake park switch circuit short to ground
B2480 LF corner lamp output circuit short to battery
B2481 Convertible top up/down switch fault
B2482 RF corner lamp output circuit short to battery
B2483 Enable circuit open circuit
B2484 Disable signal short to ground
B2485 LF side repeater lamp output circuit short to battery
B2487 RF side repeater lamp output circuit short to battery
B2489 Underhood lamp output circuit failure
B2490 Underhood lamp output circuit short to battery
B2491 RF park lamp output circuit short to battery
B2492 Already programmed (test mode DTC only)
B2493 LF park lamp output circuit short to battery
B2494 Anti theft horn output circuit short to battery
B2495 Anti theft horn output circuit failure
B2496 Anti theft horn output circuit short to ground
B2499 Courtesy lamp output failure
B2500 Courtesy lamp output circuit short to battery
B2501 LF lamp low beam circuit failure
B2502 LF lamp low beam circuit short to battery
B2503 RF lamp low beam circuit failure
B2504 RF lamp low beam circuit short to battery
B2505 LF lamp high beam circuit failure
B2506 LF lamp high beam circuit short to battery
B2507 RF lamp high beam circuit failure
B2508 RF lamp high beam circuit short to battery
B2509 Rear fog lamp switch circuit failure
B2510 Main blower motor relay circuit short to battery
B2511 Horn output relay circuit short to battery
B2512 Front foglamp relay circuit short to battery
B2513 Blower (fan) circuit failure
B2514 Blower (fan) cirucit short to battery
B2515 Heater blower relay circuit failure
B2516 Blower control circuit failure
B2517 Emergency power off system faulted
B2518 Compressor overtemp fault
B2519 High mount stop lamp circuit failure
B2520 High mount stop lamp short to battery
B2523 License lamp circuit failure
B2524 License lamp circuit short to battery
B2525 Left rear backup lamp circuit failure
B2526 Left rear backup lamp circuit short to battery
B2527 Left rear stop lamp circuit failure
B2528 Left rear stop lamp circuit short to battery
B2529 Left rear turn lamp circuit failure
B2530 Left rear turn lamp circuit short to battery
B2531 Right rear backup lamp circuit failure
B2532 Right rear backup lamp circuit short to battery
B2533 Right rear stop lamp circuit failure
B2534 Right rear stop lamp circuit short to battery
B2535 Right rear turn lamp circuit failure
B2536 Right rear turn lamp circuit short to battery
B2539 Aux A/C mode position reference circuit short to ground
B2540 Aux A/C mode position reference circuit short to battery
B2543 Aux A/C control switch reference circuit short to ground
B2544 Aux A/C control switch reference circuit short to battery
B2545 System power relay circuit short to battery
B2546 System power relay circuit failure
B2550 Lamp dome output circuit short to ground
B2553 Disable signal output circuit short to battery
B2554 Lamp dome output circuit failure
B2555 Lamp dome output circuit short to battery
B2556 Enable siganl circuit short to battery
B2557 Left power sliding door open/close output circuit short to battery
B2558 Right power sliding door open/close output circuit short to battery
B2559 Aux A/C blower motor relay circuit short to battery
B2560 Aux A/C blower motor relay circuit short to ground
B2561 Aux A/C blower speed 1 circuit failure
B2562 Aux A/C blower speed 1 circuit short to ground
B2563 Aux A/C blower speed 2 circuit failure
B2564 Aux A/C blower speed 2 circuit short to ground
B2565 Right tail lamp circuit failure
B2566 Right tail lamp circuit short to ground
B2567 Reverse mirror output circuit failure
B2568 Reverse mirror output circuit short to ground
B2569 Liftgate disarm switch circuit short to ground
B2570 Right lamp outage signal circuit short to ground
B2571 Left lamp outage signal circuit short to ground
B2580 Aux blower sense switch circuit failure
B2581 Passenger seat occupant detection circuit short to ground
B2582 Passenger seat occupant detection circuit open
B2583 Child seat detection circuit short to ground
B2584 Child seat detection circuit open
B2585 Anti theft input signal circuit short to battery
B2586 Headlamp mode select circuit failure
B2587 Passenger seat occupant detection circuit short to battery
B2588 Child seat detection circuit short to battery
B2589 Unexpected door reversal during close
B2590 Vehicle park/speed signal circuit failure
B2591 Detent signal missing during unlatch
B2592 PSD not fullt closed (module commanded successfully)
B2593 Power sliding door opened during module close command
B2594 No movement detected after an unlatch during power open
B2595 Anti theft input signal circuit failure
B2596 Headlamp aim output relay circuit short to battery
B2597 Headlamp aim output relay circuit failure
B2598 Headlamp relay circuit failure
B2599 Tailgat release open circuit
B2600 Double locking door motor frozen
B2601 No latch signal sensed on closing and door reversed
B2602 Missing latch signal during power sliding door unlatch
B2603 PSD not fully closed during self-test
B2604 Power sliding door on/off switch open circuit
B2605 Disable signal open circuit
B2606 A/C temperature sensor out of range
