Delta 1.6 GT i.e - help needed
matis
Post autor: matis » 21 lip 2005, 11:40
I have 1992 Lancia and i have problem with hoses under the hood, i don`t know are they connected rightly.
Here are the pctures of the hoses.
http://www.zone.ee/ohvroad/lancia%20012.jpg?2
http://www.zone.ee/ohvroad/lancia%20023.jpg?2
http://www.zone.ee/ohvroad/lancia%20033.jpg?2
http://www.zone.ee/ohvroad/lancia%20037.jpg?2
http://www.zone.ee/ohvroad/lancia%20026.jpg?2
Lancia fan from Estonia
matis
Post autor: matis » 21 lip 2005, 19:18
Who can translate this text above , please do it, I realy need help.
mustafi
Post autor: mustafi » 21 lip 2005, 19:33
I guess your text above is not a problem, but I can translate:
Mam Lancie z 1992. Mam problem z podlaczeniem wezy pod maska i nie wiem czy sa podlaczone poprawnie.
Maybe nobody knows whether hoses are conected correctly or they should be fixed :) You have to be patient, I hope You get answer.
Greetings from Poland
Ostatnio zmieniony 21 lip 2005, 19:39 przez mustafi, łącznie zmieniany 1 raz.
Kubek
Post autor: Kubek » 21 lip 2005, 19:38
Ok przetlumacze, chociaz i tak pewnie wiekszosc rozumie.
"Mam lancie z 1992r i mam problem z wężami pod maską, nie wiem czy są dobrze połączone/podpięte.
Oto zdjęcia węzyków:"
Nasze Forum robi sie miedzynarodowe.
You need to have patinece and surley somebody will check that for you and will write here everything about yours hoses.
But why you dont know if they are connected rightly ? You have bought a car whit out hoses ?
Kubek
Post autor: Kubek » 21 lip 2005, 19:39
ahhh mustafi byl szybszy :)
matis
Post autor: matis » 21 lip 2005, 20:15
I need somekind of wiring diagram, something like this http://www.pilt.ee/photo/344956/9245196/
But it must be about Lancia Delta 1.6 GT e.i 1992
matis
Post autor: matis » 24 lip 2005, 17:02
Please, can someone tell me should there be two hoses connected with this thing http://www.zone.ee/ohvroad/lancia%20033.jpg?2 or not.
mustafi
Post autor: mustafi » 24 lip 2005, 17:50
No co jest spece od delty I, nikt nie potrafi pomoc???
(I've asked about help for you, I hope somebody will be able to fixing your problem :) )
lancia1969
Post autor: lancia1969 » 25 lip 2005, 8:01
matis
Write me full VIN number , ZLA......
Regards,
Grzegorz :lol:
Grzegorz
GG 13364997
matis
Post autor: matis » 25 lip 2005, 14:40
ZLA831AB000570502
Anonymous
Post autor: Anonymous » 28 lip 2005, 0:20
I can't help you, i have got Delta I but oldest one, and turbo version, but could you tell more about your problem, why do you think that this hoses are connected badly??
matis
Post autor: matis » 28 lip 2005, 10:39
Then I bought my car , there were many ends which were open, so I connected loose hoses with this ends, but Iam not sure that I connected them rightly. In spring I checked my engines camshafts and the picture of them was not good, both camshafts were damaged, one of them you can see here http://www.pilt.ee/photo/344956/7873753 so I looked new ones and at the same time I did change water pump. http://pilt.ee/i/p/2/60/087786025fad75.jpg/
Then the engine finally was put together I thought that now the car should move better, but actually it moved worse. Then I decided to take my car to diagnostics, but repairmen said that I have to make sure that wires and hoses are connected rightly, because they don`t have any information about this car .
Talking about wires I would like to know what is this?
http://www.zone.ee/ohvroad/lancia%20030.jpg?2
Greetings from Estonia
Anonymous
Post autor: Anonymous » 28 lip 2005, 12:26
this is not an original part I think??! I don't know what it is :/
In my opinion hoses are connected correctly, if it were badly connected car wouldn't start, or you would heard that is something wrong I thing.
I had problems with my camshafts, but I replaced them and everything is OK, mayby you should adjust ignition and cams?? you must do all regulations . Then check that it is OK. Mayby you bought camshafts from other engine model, for example from 2.0 engine or from turbo version?? All that camshafts fit to all DOHC fiat engines, but they got other mount, they are harder or softer if you know what i mean :P I think you have problem with camshatts not with hoses. (sorry for my english :P)
Greetings
Greg
matis
Post autor: matis » 28 lip 2005, 13:08
New cams are from 1.6 l engines, that I know and about this hoses if I pull them off, then the engine works, then just a littel rpm changes but I think this engine working problems will be solved when I go to the diagnostics.
matis
Post autor: matis » 29 lip 2005, 10:17
I think it is original part, this Lancia has it also.
http://www.zone.ee/ohvroad/lanci-delta- ... gine.jpg?2
Ostatnio zmieniony 30 lip 2005, 17:49 przez matis, łącznie zmieniany 1 raz.
