Nowy Chrysler 200 (2014)
Re: Nowa Lancia Flavia III 2014 (Chrysler 200)
Post autor: broker » 18 mar 2013, 23:02
Nowy Chrysler 200 - debiut styczeń 2014, Detroit.
The generation 200, which we have listed as to be built starting between January and May 2014, was being led by Lancia people when we last saw it; it is likely to be sold as the Lancia Flavia in convertible and sedan form. The 2015 Chrysler 200 will have a Chrysler 2.4 four-cylinder, and the 3.2 V6, possibly with a 3.6 option as well. The 1.4 liter Fiat engine has reportedly been axed, at least for American markets, though the similar Alfa Guilia will use the 1.4 turbo and the Alfa 1.8 direct-injection turbo engine and a 2-liter diesel.
The 200 will have the nine-speed ZF automatic, and a 38 mpg target in a special ?HFE? model. It will bring out the new Chrysler/Lancia ?style language? which will later be adopted by other Chrysler cars and minivans ? though not, for some time, the 300.
The ?UF? body code shows up as ?Sebring? in Chrysler?s systems. It was probably just entered before the name change, but there is a small possibility that the Sebring name will return, leaving the alphanumeric 300 alone at the top of the Chrysler lineup. That would emphasize the 300?s luxury versus the Sebring?s ?cover everything? role.
Chrysler CEO Saad Chebad told us: I can?t tell you right now? what we?re going to do with the 200. All I can tell you is that it will be an extremely competitive vehicle in the marketplace. At the same time, it?s not going to be ? it?s not the 200 of today. [The segment] went up in design and quality and content, so there?s this movement in the marketplace as well, in the D segment. There?s a lot of people coming from E segment size cars to D because the D segment cars are getting also bigger, right? So you have to take that into consideration, that that car has to stretch from people coming from E, you know? And luxuries and everything else? as well as you still have that mainstream D segment customer that you?ve got to attend to in many different ways. ? You?ve got fleets, you?ve got this, you?ve got that, you?ve got all sorts of things you?ve got to keep in mind.
Post autor: hitmanag » 20 mar 2013, 21:32
Post autor: broker » 08 cze 2013, 21:28
Odbyła się już ukryta prezentacja Chrysler'a 200, który zadebiutuje w styczniu w Detroit (Lancia w marcu w Genewie ?).
Ponoć styl to kombinacja klasycznych i nowoczesnych elementów.
Ci co widzieli projekt twierdzą, że Chrysler/Lancia będą miały znakomitą broń na europejsko-azjatycką konkurencję w segmencie D.
Dla Chrysler'a to najważniejszym model w ich ofercie, dla Lancii sukces nowej 'Flavii' jest niemal krytyczny.
Raczej można być pewnym perfekcyjnego samochodu i jedocześnie wyróżniającego się dizajnem, jak zbierze się dotychczasowe informacje oraz chęć Chrysler'a, żeby tym modelem rozpocząć nową erę w historii marki.
Za pojektem stoją zarówno Włosi jak i Amerykanie.
Art92
Post autor: Art92 » 27 cze 2013, 13:45
Całkiem nieźle się zapowiada. Ciekawy design choć mało ma wspólnego z włoskim wzornictwem.
VW Sweter 1.9 TDi. Od czasu do czasu ujeżdżam Chevrolet Cruze 1.6
Wilkin
Post autor: Wilkin » 27 cze 2013, 13:56
broker pisze:Dla Chrysler'a to najważniejszym model w ich ofercie, dla Lancii sukces nowej 'Flavii' jest niemal krytyczny.
Jak w końcu zrobią dobrą reklamę - to i samochody zaczną schodzić ;)
Tak z grubsza ;)
Helios
Post autor: Helios » 27 cze 2013, 15:57
Art92 pisze: Ciekawy design choć mało ma wspólnego z włoskim wzornictwem.
A skąd wiesz jak będzie wyglądać auto którego jeszcze nie pokazano :?:
Post autor: hitmanag » 27 cze 2013, 17:19
Życzę sobie i Lancii, aby model odniósł sukces.
Post autor: broker » 18 wrz 2013, 13:27
W końcu już nie muł na bazie Giulietty, ale faktyczny model.
Autorzy bloga na podstawie fotek twierdzą, że linia wskazuje na rewolucję dla Chrysler'a i tylko ewolucję dla Lancii. Samochód będzie mocno 'włoski'.
Grill powinien być stosunkowo mały (jak Kappa czy Lybra).
Samochód powinien być elegancki, ale i trochę sportowy zarazem (co by tylko potwierdzało wcześniejsze zapowiedzi szefostwa marki Chrysler).
Camouflage hides perfect lines D-segment Lancia
Helios
Post autor: Helios » 18 wrz 2013, 16:16
Trzymam kciuki aby powstała Flavia :D Znając Sergio to może tego nie zrobić.
Post autor: hitmanag » 18 wrz 2013, 16:21
Ja też trzymam kciuki.
To że nowy Krajzler powstanie to nie mam wątpliowści, pytanie właśnie o siostrę czy się pojawi?
paśny
Post autor: paśny » 18 wrz 2013, 17:06
No chyba powstanie - była mowa o rebadżingu.
Viva la macchina
Post autor: broker » 18 wrz 2013, 17:10
Też sobie nie wyobrażam, że nie będzie Lancii w Europie pod tym modelem. Przypomnę słowa jednego z szefów Chrysler'a (Mr Gilles).
?Wait until you see the new 200, your faith in Lancia will be restored.?
Post autor: hitmanag » 18 wrz 2013, 17:12
Oby w tym wypadku dotrzymali obietnicy!
Post autor: Dudi » 18 wrz 2013, 18:36
Oby tylko światła z tyłu nie były poprowadzone tak, jak ten szary pas :roll: : buja w oblokach : ;)
Post autor: broker » 18 wrz 2013, 19:01
Niemożliwe, takie ma tylko Dodge ;)
